Fixing small cracks on aluminum engine parts
  • Darkangel
  • Darkangel's Avatar Topic Author
21 Feb 2009 21:47
#266979
I pulled off my cover to my stator, and BEHOLD! THERE WAS A FRIGGIN CRAKE AT THE VERY BOTTOM! I had just started to degrease the engine because of caked oil and dirt everywhere, and I feared that maybe there was a something more serious going wrong with the engine. Good news, there isn't. Bad news, there's a crack on the stator cover....How can I fix it with out getting a used stator cover? mig or tig it, jb weld....what is something that will work very well?
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
  • timebomb33
  • timebomb33's Avatar
Re: Fixing small cracks on aluminum engine parts
21 Feb 2009 22:10
#266993
i've had good luck with jb weld in the past but depending on the size of your wallet i probably would look for anew or quality used one as ive never had any luck welding crack up in oil soaked alloy plus the extra heat can and often will warp the gasket surfaces so then you would have to machine it true again.if you jb weld it give it lots of time to cure and try to do both sides of the crack internal and external.
I THINK MY POWERBAND BROKE
  • Darkangel
21 Feb 2009 22:50
#267011
yeah i dont know where to find another stator cover....I've been looking on ebay...I will JB it, and if that doesn't work...then i will tig it...
  • kano
  • kano's Avatar
  • Not Another Bloody Limey!
21 Feb 2009 22:52
#267012
what motor thought i saw one on e-bay.
how duz jb weld hold up to heat?
  • kzz1p
  • kzz1p's Avatar
  • One Test Is Worth A Thousand Expert Opinions!
21 Feb 2009 23:06
#267017
Here's my three cents. The best stuff I have ever used to repair or patch alum. is called Devcon. It comes in two cans, mix them together and it starts smoking. (it makes you feel evil) I have seen other people patch cases and even make new fins to replace old broken ones. It comes in three different types. Alum, Steel, Cast Iron. People have even used it to patch blocks on tracters. The only hold back is it costs about $25.00 or so! (yes you can get a new cover cheaper) But the two cans will last you for a long time. Maybe not if you blow up alot of stuff.
  • timebomb33
21 Feb 2009 23:12
#267020
devcon does work well we sometimes use it to raise the floors in the intake ports when porting the reason i suggested the jb weld is that it's readaly available and it does hold up quite well to oils and heat and it is easy to work with [filing and sanding] and would cause any distortion like welding would and also everybody has heard of it or used it at some time in there lives.
  • Darkangel
21 Feb 2009 23:14
#267021
Devcon Aluminum Liquid F-2
makers of permatex.....is this the stuff...it's 45 bones
  • kzz1p
  • kzz1p's Avatar
22 Feb 2009 00:37 - 22 Feb 2009 00:38
#267036
Never used liquid, it's a paste. I don't about permatex...It could be that high in price. Just put that out there for those who don't know.
Last edit: 22 Feb 2009 00:38 by kzz1p.
  • twfields79
  • twfields79's Avatar
22 Feb 2009 08:00
#267086
Not to highjack the thread but do you think that devcon would hold this very good? would it be sturdy enough to fix this?
1978 KZ650 B2
22 Feb 2009 08:23
#267091
twfields79; I would have that welded. It won't cost much, and you won't have to worry about it breaking again. Ed
  • twfields79
22 Feb 2009 08:35
#267096
Okay well wouldnt that be braizing? And you think it would be fairly inexpensive?
1978 KZ650 B2
22 Feb 2009 09:07
#267104
Not brazing. That piece looks like aluminum, but I can't tell for sure. If it is, aluminim can be welded using Shielded Metal Arc Welding (SMAW) - also known as stick electrode welding or Tungsten Inert Gas (TIG) or Gas Tungsten Arc Welding process (GTAW) - also know by old guys like me as heliarc welding. Welded aluminum is very strong. It shouldn't cost much to have that small piece done, but call around first to get pricing. Ed
