ELR Clone Canidate? Opinions?
- NakedFun
20 May 2014 09:57
A quick question to the collective: If you were to build an ELR clone, what bike/year/model would you prefer to start with? I am keeping an eye out to build a second KZ that would look like the love child between an original ELR and a later ZRX. Any particular models I should keep an eye out for, let me know.
Cory
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
1976 Kawasaki KZ900
- Dr. Gamma
Re: ELR Clone Canidate? Opinions?
20 May 2014 10:02
Just find a 1981/1982 KZ1000J. Thats what the KZ1000R (ELR) was based on.
Then find a 1981/1982 GPz1000 fuel tank.
That would be a great start to your clone of a ELR.
1986 RG500G 2 stroke terror.
- Mcdroid
- Gone Kwackers
20 May 2014 11:08Dr. Gamma wrote: Just find a 1981/1982 KZ1000J. Thats what the KZ1000R (ELR) was based on.
+1 What he said!
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- NakedFun
20 May 2014 11:50
So the GPZ tank is the same tank as the KZ1000R? That is very helpful.....
Cory
Cory
1976 Kawasaki KZ900
1976 Kawasaki KZ900
- baldy110
20 May 2014 12:28
i searched for over a decade trying to find a KZ1000J to base an ELR cone on, I never found one. I ended up using an 82 GPz750 frame and swapped in an 82 GPz1100 engine.
If you are going to use a J model you will need the tail and tank from an 81 or 82 GPZ1100, they match the ELR ones. You will also need the oil cooler and adapter from the same years GPz1100. You can use the Maier GPZ universal fairing, it's pretty close the ELR one.
- Mcdroid
- Gone Kwackers
20 May 2014 13:40 - 20 May 2014 13:42
Here are a few more tips...if you can find a KZ1000J model, and you retain the stock round headlight, you need the Maier GPz style front fairing with the round opening. If you opt for a more 'R' look, you'll have to get a rectangular headlight shell and match that with the Maier rectangular GPz-style fairing. If you can actually locate an original Gpz1100 fairing (note that the 1982 GPz750 fairing is identical to the 1982 1100 fairing)....make sure it comes with the mounting bracket hardware and the gasket which mounts between the windscreen and fairing. The brackets and gasket are even rarer than the original fairing and are unavailable aftermarket. Note that baldy110 has chosen a GPz550 front fairing...they are far more common and easy to source. Opt for a 1982 GPz1100 fuel tank and cap the fuel pressure valve on the underside of the tank. The petcock placement on the 1981 tank will interfere with the tops of the carbs on the KZ1000J while the petcock on the 1982 model tank is set further back and is a drop-on change.
Note also that baldy110's bike is a work of art.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 20 May 2014 13:42 by Mcdroid. Reason: clarity
- Mcdroid
- Gone Kwackers
20 May 2014 13:52 - 20 May 2014 13:55
And I overlooked the easiest solution...locate a 1981 or 1982 GPz1100 and paint it ELR colors. Leave the FI alone if possible...if not, convert to carbs. Note that the instrument pod on the 1981 will not allow easy mounting of the 'R' style fairing...you'll have to fabricate a mounting mechanism.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 20 May 2014 13:55 by Mcdroid. Reason: clarity
- gengomerpyle
20 May 2014 14:23baldy110 wrote: i searched for over a decade trying to find a KZ1000J to base an ELR cone on, I never found one. I ended up using an 82 GPz750 frame and swapped in an 82 GPz1100 engine.
was it hard to fit a 1100 engine in the 750 frame?
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
1971 Honda CB750K
- Mcdroid
- Gone Kwackers
20 May 2014 14:26gengomerpyle wrote:baldy110 wrote: i searched for over a decade trying to find a KZ1000J to base an ELR cone on, I never found one. I ended up using an 82 GPz750 frame and swapped in an 82 GPz1100 engine.
I seem to recall a thread by baldy110 discussing his tribulations installing the 1089cc beast in the 750 frame...maybe he can post the link?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- NakedFun
20 May 2014 15:24
I am leaning toward a GPz1100 convert. Seems to make sense. It is not going to be an "accurate" clone as it will have forged aluminum wheels with fat rubber, swing arm conversion (probable another ZRX) and big brakes. More of a race bike look. I'll keep my eyes open for a GPZ, but I still need to finish my current KZ. Just riding my ZRX the last few weeks has gotten me in the mood for a ELR.....
Cory
Cory
1976 Kawasaki KZ900
1976 Kawasaki KZ900
- peter1958
20 May 2014 15:43
I have a front faring left . I used to have all the other parts pm me if you need it there is no windsheild and it would need paint but its off my elr
www.kzzone.com/
The following user(s) said Thank You: NakedFun
- NakedFun
20 May 2014 16:49peter1958 wrote: I have a front faring left . I used to have all the other parts pm me if you need it there is no windsheild and it would need paint but its off my elr
Pete,
Thanks.
Cory
1976 Kawasaki KZ900
1976 Kawasaki KZ900
