2 Questions VIN Numbers and Engine Color
  • cashmore1985
  • cashmore1985's Avatar Topic Author
12 Aug 2008 21:26
#231708
I have what the title says is a 1973 Kawasaki Z1. However, everything I've seen says the engine should be black. Were all the '73s black on the engine? Also, how would I know if my engine number went with my frame number? Thanks.
1973 Z1 900. Currently ratty. Black Mac Performance 4-1 canister exhaust. Emgo Pod Filters, LTD Seat, 3 point crash bars, big ass touring screen. Work in progress.
  • donthekawguy
  • donthekawguy's Avatar
Re: 2 Questions VIN Numbers and Engine Color
12 Aug 2008 23:33
#231719
Yes all the motors were black. As for the engine number I think you might be able to look up the number to find out what year it was made but there is no way to tell if it is the original motor in the bike.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • supercharged
  • supercharged's Avatar
13 Aug 2008 00:00
#231723
Mike D
- 79 KZ1000 LTD Supercharged
- 80 KZ1000 1105cc Pridmore/Vetter tribute
- 79 Honda CBX
- 03 Z1000 Mod
- 80 KZ1000 LTD Modified
- 80 KZ1000 LTD PROJECT on Hold
- 78 KZ1000/900 - Street big block
- 78 KZ1000-NEEDS HELP!
- 80 CBX -Project STARTED
- 81 GPZ1100
- GSRX1200
- 80 CB750F supersport......
  • Jack
  • Jack's Avatar
13 Aug 2008 06:42
#231739
You don't say where you are located but I've seen a lot of "mis titled" bikes in USA. Seems some bikes get registered by the vin plate/date of manufacture on steering head rather than actual model year.In Ontario the bike is registered by the mfr. model year ,not the date of manufacture.
So, you may have a 74 Z1 with an unpainted silver engine titled as a 73 based on the steering head sticker.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
  • cashmore1985
13 Aug 2008 08:32
#231756
You may be right about that. I am in Virginia. The frame number is powder coated over, so you can't read it all unless you have the right light angle. I haven't even tried to read it really. There were a few other things that didn't quite go with it being a 73. I don't really know what the deal with it is, but that sounds like a logical reason for it to say 1973 on the title and have a silver engine.
  • cashmore1985
13 Aug 2008 08:35
#231758
I read that thing on Z1Enterprises.com and someone can correct me if I'm wrong but my engine number is Z1E10830, which follows with it being a 73, but my engine is silver, maybe someone removed the black coating? I have no idea, I will have to get in and look at the frame to see if I can find the number on it.
  • Limey
  • Limey's Avatar
  • 3 Years in the U.K. - Brought the KZ with me!
13 Aug 2008 09:43
#231771
Jack wrote:
...Seems some bikes get registered by the vin plate/date of manufacture on steering head rather than actual model year...
Prior to the standardization of the VIN in 1981, there tended to be a lot of confusion about dates - manufactured, model year, registration. I know of vehicles that have a model year based on the date of first sale - sometimes two years after the actual model year!
Eric
Newmarket, England (for 3 years)
Pentwater, Michighan (Home)
1978 KZ650
2000 ZG1000
2006 Suzuki Burgman 650
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
13 Aug 2008 10:08 - 13 Aug 2008 10:11
#231774
Cashmore1985...if your 1973 Z1 is truely a Z1 (not a Z1a or Z1b) then your frame number will be less than 20000...to have some degree of assurance that your engine VIN will be also of Z1 pedigree, then it will be within 300 or so of your frame VIN...phrased differently, if your frame VIN is Z1F010830, your engine VIN will be +/- 300 of 10830. If you get any wild variances from that relationship, then it is likely that at least the engine cases have been replaced. It becomes less of a pure Z1 at that point.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 13 Aug 2008 10:11 by Mcdroid.
  • Jack
  • Jack's Avatar
13 Aug 2008 10:40
#231778
If the engine was originally a black Z1 unit from KHI it will have black paint inside the engine as well. ie. check under your rocker or clutch cover.
79 KZ 1075 MKll
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
