Like I have nothing better to do
  • Cra-z1
  • Cra-z1's Avatar Topic Author
Yesterday 11:44 - Yesterday 11:47
#928823
My 74 Z1 has been leaking a bit of oil since I bought it 15 years ago from a friend just before he passed away. The bike is pretty much original With 24,000 miles except for new pipes, tapered steering bearings and a Dyna S. I have been hesitating to take care of the leaks  for the last 14 years. So I finally had enough and tore into it a few days ago. I like to make my own gaskets using Felpro Karropak gasket material 1/64 and using a light smear of Curil T2 Gasket maker. So I replace all of the gaskets including the oil pan along with shaft seals. I also spliced in a new harness for the alternator using a new rubber grommet. I like to strip off the cloth cover and use a strip of heat shrink where the wires go into the rubber grommet. Before I install the grommet I coat the area where the grommet sits with Quick silver bellows adhesive so they slid easy into the grommet. I seal the inside of the grommet with the bellows adhesive where the wires enter and also use the adhesive on the edges of the grommet. Over the years I found this has been the best way to seal that area. Still waiting on a few lip seals. While the covers were off I took the time to polish them. The bike should be pretty much leak free after to work.
Last edit: Yesterday 11:47 by Cra-z1.
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
Re: Like I have nothing better to do
Yesterday 13:22
#928827
I like making gaskets too but seeing this I might have to up my game. Started out making transmission, transfer case and differential gaskets for my buddy's 41' Dodge 1/2 ton weapons carrier back in 1980. Our favourite gasket material was cold pack beer boxes. We couldn't buy the gaskets but had a nice hole punch set. My buddy still has the truck.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
  • Move0ver
  • Move0ver's Avatar
Yesterday 13:40
#928829
So this was just released by PMC in japan:
japan.webike.net/products/26719496.html
its a metal core gasket set for the Z1 using a 0.2mm SPCC (steel) core material.  Supposedly it significantly reduces oil seepage compared to conventional resin-based gaskets, as well as not sticking when being removed.
I'll probably order a set for my winter refresh/service.
  • Cra-z1
Yesterday 14:50
#928831
Let us know how they look/work. Probably one time use? Not a problem except for the valve cover and clutch cover.
