'82 Z1000 LTD "Terry Lee"
- Marneman
Re: '82 Z1000 LTD "Terry Lee"
13 May 2011 01:23
I bit the bullet and pulled the cylinder head afraid of what I might find. Turns out the jugs were spotless and my smoking issue was related to 29 year old valve seals :woohoo: A few of the valves were very carboned up and it appeared the bike had been running way rich on a couple cylinders. They cleaned up great and gave the valves a quick lap and some new viton seals.
Here is a pic of my high end HF valve spring compressor. :woohoo:
Total cost $7.00 and a piece of scrap tubing. Not fancy but worked flawlessly. I will get some more pics up this weekend. Got the rear end tore apart tonight and hope to get it cleaned up this weekend. I figure 1.5 more orders from Z1 (gaskets, cables, chin & sprockets, etc), paint and some tuning and she should be almost there.
Later.
Later.
77 KZ1000-A1 "Bushido" Project
82 KZ1000 LTD "Terri Lee"
You know what, I don't have a one to some other number of douche-bag scale. So.. Six!
- testarossa
13 May 2011 08:17
Good to see you making progress. I has seemed that all my favorite projects have stalled out.
I like the custom HF tools.
1.5 more orders from Z1E. :laugh: I must have said that at least 10.5 times.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
16 May 2011 10:37
glad the engine looked nice inside.that a relief,good progress sir!
keep us posted,
keep us posted,
- Marneman
19 Jul 2011 23:48
Well I've made some decent rogress over the last few months, and I figure I'm overdue for posting some pics. Since last time I got the swingarm squared away, the head done, clutch springs, stator cover polished, and most of the base coat done on the pretty parts.
I'm liking the superbars and the stance so far. What do you think of the KZ650 tail? I did alot of thinking on that one, and I'm starting to like it more. It requires me to shorten the LTD seat pan some, but I wanted to change u the seat to something sportier anyways. More to follow. Should look ok with the rear fender eliminated and a new integrated turn signal "ala Testarossa". Remember Josh, imitation is the sincerest form of flatery, and I like the R6 tailight of yours. What ya think?
- Marneman
19 Jul 2011 23:56
For the not so cool, I decided since I had the head off, I might as well pill the cylinder just to be sure, since it was smoking some last time it ran. Well good thing I did, turns out the previous owner managed to overlap the oil expander rings on two cylinders which have managed to chip off the very ends of two of the expander rings. The rest of the rings look great, but better safe than sorry right? So I will add a re-ring to the parts list
The jugs don't look bad at all, still showing the hatch marks from the last ring job. Oh well, time and money. Maybe I will appreciate it more when done? At least I will know where I stand when she's all buttoned up.
I hope to get the fender eliminator / taillight mount goin this weekend. I'll try and get some pics up if it turns out like I think it should. If not, I will lie, and say I changed my mind at the last minute :lol:
- testarossa
20 Jul 2011 08:21
Looks good. I always liked the tail piece on the KZ650 it should be fine on your bike.
Let me give you a pointer about that taillight. Make your electrical connections so that you can remove them. What I did was wire the new light into the old KZ1000 taillight plug, so it plugs into the factory harness like normal. The reason that I say this is that you want to leave the taillight disconnected when you first get the bike running. That way you can check the condition of your charging system. I had a bad regulator and the bike was charging at about 17.5VDC at 4000 rpm. That was too much for the taillight, and it killed something on the circuit board. I had to get another light along with a new regulator/rectifier combo to fix the problem. Another $150 down the tubes on that deal. I could have saved myself $50 if I had checked the electricals first.
BTW good call on the superbike bars, they're my favorite. Natural riding position for my gorilla arms, and they look right on the bike.
So have you decided on a paint scheme? I can't remember if you already said something about that.
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
20 Jul 2011 09:47
looking good so far.
i like the 650 duckbill it looks good there.the leading axle front end tho has me thinking i might want a 77-80 dual disk front end perhaps.
just thinkin.
the front end you have is fine,but the leading axles always perplex me :S .
not a deal breaker,just a head scratcher.
keep us posted,
just thinkin.
keep us posted,
- Marneman
25 Jul 2011 00:32
Thanks for the tips fellas. And thank you Josh for spending the money to make sure that no one else had the same issue :laugh: . Seriously, I have learned alot of life lessons the same way, ever try and chase down a charging issue on a Ford? Replace battery, replace alternator, and finally replace voltage regulator. Which ever order you decide, it will be the last thing you try that was the original problem. Ask me how I know? Who needs a trouble shooting chart right?
I had the same issue with the "look" of the LTD forks. I definately don't like the looks compared to the same year J model forks. I wonder if I could just switch out the lowers, and have everything else bolt up? Couldn't be that easy though could it. Will do some research on that one.
Right now the paint scheme is.....ready for it....gloss black! I ran through a bunch of color combos in my head, but I kept coming back to black, always classy. Awful tempted to do some silver racing stripes on top, ala Josh. It could be the decepticon version of his paint scheme.
Took the cut off wheel to the seat pan this evening, no turning back now. Now before anybody gets worked up that I destroyed a rare vintage 82 LTD pan, it was ugly to start with, and the thing was FUBAR when I started. Sand blasting took care of the cancer issue, and some spot welding and a hammer got her close to original shape. Looked like an elephant had sat on it. I made sure after I fixed it to sit on it again myself to make sure my large ass wasn't the problem. Took about 3 - 4 inches off the back, and will rebuild the bracing on the back for rigidity and to match the contour of the 650 tail piece. Otherwise fits just fine. Gonna try and go with the ZRX look for the finished seat. More to follow...
- Marneman
01 Aug 2011 23:24
So my sacrificial ZRX seat arrived, as I hadn't actually compared one with my LTD pan, I wasn't sure how it would work, but it looked like it might work from the pictures. I was fortunate that the seat arrived in like new shape! From the looks of the foam and the cover, it doesn't look like it was used at all.
Here is my cut down LTD pan...
I had to trim the foam a tad, but overall it looks like it was meant to be..
It's just sitting on there for now, as I need to trim up the edges of the pan, and paint for rust protection. I'm very pleased so far. Thank you to Mark for the inspiration
I'll get some more pics once it's all buttoned down.
02 Aug 2011 11:29
pretty danged close.
(the front of it looks like it might want to match up to a square tank :evil: :whistle:
can't wait to see how it turns out.
keep us posted,
keep us posted,
- mark1122
- Keep twisting it
03 Aug 2011 17:13Glad i could help.
That seat looks like it is going to blend right in, now that u have created a step in the kz pan.
i think u are going to be pleased with the look.
Keep up the good work.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- jydog
22 Aug 2011 17:40
Hey, how's the seat comming out? do you have it finished yet? Im in the middle of looking at different seat options for my 81 kz and wanted to see how yours is comming out. I would like to narrow my pan to conform to the frame more and make it sit as low as possible. I know it's a lot of work and certainly not a bolt on process. I hope your progress is comming out easier than mine.
81 KZ1000 LTD
Griffin GA
Griffin GA
