Advanced Search
Search Results (Searched for: ZRX shocks)
Replied by Nebr_Rex on topic ZRX shocks on my kz650?
15 Sep 2011 22:17
Nebr_Rex's Avatar Nebr_Rex
ZRX shocks will be way to long and the spring way stiff for a 650.
I will measure both my SR and ZRX tomorrow morning and report back on the length.
ZRX should be about 14 1/4 to 1/2 in. and SR 12 1/2 to 13 in.
Replied by mark1122 on topic ZRX shocks on my kz650?
15 Sep 2011 19:11
mark1122's Avatar mark1122
buy haveing the forks above the top tree, it makes it steer quicker (easier.) put them where u like the steering action best. the down side to having the forks above the trees is that u loose some ground clearance.
u could give the zrx shock a try . if u are not happy u can get your money back through ebay.
i have them on my kz1000.they are about 1" longer than my stock shocks.
since they are 1 inch or more in your case ?, longer, i would put the forks back to the stock position.
Replied by bearshawk on topic ZRX shocks on my kz650?
15 Sep 2011 12:23
bearshawk's Avatar bearshawk
Patton wrote:
bearshawk wrote: hey guys is this possible? i have a lead on a good set nearby and thought it would be a good improvement, i am 230# and i often ride two up i figured even with the inch+ longer shock it will be a better ride for me.
has anyone else done this mod?
Might simply raise the rear end without adding any additional suspension travel. And which usually quickens the steering (which might aggravate head shaking tendency).
The spring rate may be a more important consideration.
Sometimes it helps to equally increase the pre-load on both shock springs.
Good Fortune! :)
so if im looking for aftermarket shocks its probably not the best route to go?
i noticed yesterday while looking at my bike that the forks are about 3/4 inch ABOVE the upper triple. i looked in the manual and its supposed to be JUST BELOW the upper triple...this is how i got the bike and i assumed this was how it was supposed to be, should i raise it back up?
Replied by Patton on topic ZRX shocks on my kz650?
15 Sep 2011 12:05
Patton's Avatar Patton
Good Fortune! :)
ZRX shocks on my kz650? was created by bearshawk
15 Sep 2011 10:59
Warning: Undefined variable $end_tag_params in /home/kzride5/public_html/libraries/kunena/External/Nbbc/src/BBCode.php on line 2298
Replied by KZ_Rage on topic 1979 KZ1000ST almost done
14 Aug 2011 23:01
KZ_Rage's Avatar KZ_Rage
I've have the same bike and have had the pleasure of those shocks on my own ZRX and even though I haven't had them together on the same bike I can only say that compared to stock shocks it would have to be as much of an improvement as you can imagine. Tim has just got this bike back together and will be giving us all a review on as much of the bike, etc. after his long haul trip he is taking on it.
Replied by fxdl2051 on topic 1979 KZ1000ST almost done
14 Aug 2011 00:49
fxdl2051's Avatar fxdl2051
>The shocks are original Kawi equipment (made by KYB) on the 2000era ZRX 1100 and 1200's.<
How are the shocks working out for you, do they work better than the stockers? Great pinstriping job BTW.
ss^,
Ken
Replied by KZ250LTD on topic 1979 KZ1000ST almost done
09 Aug 2011 14:44
KZ250LTD's Avatar KZ250LTD
fxdl2051 wrote: Awesome restore. Who makes those rear shocks and where'd you get them? How'd you do pin stripping on the tank, is it a decal, if so for what model and again from where? Lastly, how do you like the Avon's?
Down the road I'll be doing some things to my own ST, you're definitly an inspiration.
Best,
Ken
Pinstriping was done by hand by Greg Sabatini at Sabatini Autowerks in Rowlett, TX. Haven't had a chance to test the avons yet but I'll let you know.
Motor Head wrote: Stay away from those Bears! Be safe and have fun.
We'll try! Knowing our luck we'll probably get a moose this year :laugh:
Replied by mark1122 on topic 76 KZ900 upgrade
24 Jul 2011 11:15 - 24 Jul 2011 11:17
zudikaszrx wrote: [quote=
I would of slanted the shocks more forward to raise the back end a bit or rotate the eccentrics.
in the newer pick i have the shocks laid down more at the top, towards the front.
u have to remember that this frame is dif.than the zrx.
i copied the shock angle of the zrx, so the shock action is the same as yours. but this brought issues . the output sprocket to swingarm axle spacing is dif. on modern bikes, so this causes chain tension issues as u raise the rear end, above the stock kz geometry. i had to run the chain looser, and add a idler wheel, to pick up the slack. raising the rear also lessens the rake . i had to modify the front trees to try to gain some of the lost clearance, and level the bike a bit. the clearance is not a big deal on the street , but huge on the track. the front end isnt bad but it could stand a little more trail.
thanks for the kind words.
Replied by zudikaszrx on topic 76 KZ900 upgrade
24 Jul 2011 02:20
zudikaszrx's Avatar zudikaszrx
mark1122 wrote: I thought i should finaly add a few updated pics.
Very nice bike.
I was thinking of doing the same to our 73 Z1, Rear swingarm and wheel off of ZRX and front forks too..
But she shot down the idea. I will keep working on her.
Really like the bike!
Displaying 341 - 350 out of 677 results.
