Search Results (Searched for: ZRX shocks)
Replied by rstnick on topic ZRX1100/1200 KYB shocks on KZ750E?
13 Dec 2021 16:42Replied by Highway Magician on topic ZRX1100/1200 KYB shocks on KZ750E?
09 Dec 2021 15:26Replied by Highway Magician on topic ZRX1100/1200 KYB shocks on KZ750E?
09 Dec 2021 12:30Replied by Highway Magician on topic ZRX1100/1200 KYB shocks on KZ750E?
09 Dec 2021 11:47
I got rid of the 40 year old pogo-stick shocks, and installed ZRX shocks on my '82 GPZ1100. Check for shock spring to chain clearance (it's real close).
You can keep most of the chain guard by removing some material, like they did with the ELR chain guard. There's even a special bracket to stabilize
the chain guard (#11036).
You can see what the chain guard looks like on my GPZ, after it was trimmed.
At some point, I will probably have the shock moved outboard, using a new mount from Z1 Enterprises (part #DC104CL. $9.95/ea.)
Replied by ThatGPzGuy on topic ZRX1100/1200 KYB shocks on KZ750E?
09 Dec 2021 09:40Replied by Nessism on topic ZRX1100/1200 KYB shocks on KZ750E?
09 Dec 2021 09:01
You might want to check clearance at the exhaust if the stock system is being used.
Replied by stinkfinger on topic ZRX1100/1200 KYB shocks on KZ750E?
09 Dec 2021 08:23 - 09 Dec 2021 08:24
Jim,
With the shocks being a little longer, and coming off of a heavier bike presumably having a stronger spring, how drastically did that affect your ride height?
Did you do anything to compensate for it (i.e. new or modify springs)?
Along those lines, with springs/dampening designed for more weight do they still work well on a 750 sized bike... in other words, would you do it again?
Replied by martin_csr on topic ZRX1100/1200 KYB shocks on KZ750E?
09 Dec 2021 05:54 - 09 Dec 2021 05:54
Since it's been answered already. From the only KYB pair I saw on EB, my eyeballs tell me it's kind of obvious that the coil spring will rub the chain guard, since the spring extends almost all the way to the lower shock mount. The lower section of KZ shocks below the springs is kind of narrow.
09 Dec 2021 05:46
I have them on my GPz750. They are a little longer, interfere with the helmet lock (I removed it) and rubbed on my chain guard which I had to modify.
ZRX1100/1200 KYB shocks on KZ750E? was created by stinkfinger
08 Dec 2021 20:53
I need to replace my worn out KZ750 shocks. It appears that ZRX takeoff KYBs can be found for $200-$300.
A search revealed that this has been asked before, but I find conflicting information... "bolts right on"... "too long"... "too wide, interferes with chain". Just looking to hear from someone who's actually done (or attempted) it.
Thanks!
Thanks!
Displaying 31 - 40 out of 677 results.
