Search Results (Searched for: ZRX shocks)
Replied by 893cv on topic KZ1000 Suspension. What have you done to your KZ?
03 Jan 2013 01:33Attachment IMAG0033_2013-01-02.jpg not found
Luis,
Race Tech sells Gold Valves and proper rate springs for the ZRX shocks. I am using a set of YZF600r cartradge forks on my 1980 KZ1000 ltd. They are 1.25 inches longer then the stock KZ forks so I won't have to worry about ground clearance.
Replied by SBK Racer on topic KZ1000 Suspension. What have you done to your KZ?
02 Jan 2013 22:07 - 03 Jan 2013 18:02
Well, I figure I see what it takes to mount ZRX1200 Shocks on the KZ1000 They are 9/16 longer than stock shocks I spaced the left shock 3 mm, and removed 3 mm off the top of the chain guard tab...
Settings:
Lowest Pre-load.
2 Rebound.
2 Compression.
The ride height is welcome... The suspension travel increased... And, the quality of ride is 10 times better... I went on a bumpy road... I could only feel the front end...
Now that I have the spring specifications I will look into 1.0 kg/mm straight rate springs and either 20W Fork Fluid or Racetech Gold Valve Emulators...
Luis
Settings:
Lowest Pre-load.
2 Rebound.
2 Compression.
Oh I still think it will be a fun bike... Not just to ride but also to work on it... Especially once I review every part and bolt on the chassis and re-engineer it to my liking...
I had to stop my self from buying parts today, because I actually want to have have a clearer idea of what I want...
I think I want lighten it up a bit first, I know the Police fairing is going to come off. I am definitely going with a simple round headlight... I saw a KZ1000 LTD front fender I like much better than the KZ1000P front fender.
I am going to hold off to front end and rear end conversions... But, I am going to work with the suspension... Firm it up a little. I am buying some ZRX1200R adjustable KYB shocks... These look to be a simple bolt on operation.
If I am not mistaken the stock fork spring rate is 0.620 kg/mm. I am probably going to install stiffer springs on the front... I think with 1.0 kg/mm springs the bike will handle better and wont dive as much when I brake. Also a Gold Valve Cartridge Emulator kit from Racetech would be a good call.
This will keep me busy for a little bit...
I would like modern brakes, and steel braided brake lines...
I would like to remove the big foot rests, in favor of standard foot pegs and foot controls...
I would like lower handlebars...
This looks nice too...
Luis
I have two kzs a 79 and an 80 and have always run them as fast as the bike wants to go. Never have I had any hint of wobble in them, ever. Maybe someone hit the front end? Maybe the head bearings are worn out? Time to replace with the upgraded roller bearings? My problems that I have noticed were with my head bearings and old shocks. Of course they don't hold a candle to the handling of the ZRX so I am just going to enjoy the Rex in the corners and ride the kz as hard as I can ride it to the best of it's limits. Now if this were my daily I definitely would upgrade as much as possible to make it handle. Wait a second, I think the new progressive shocks and box swing arm along with the progressive springs and roller bearings in front should help a little.
If you have a classic Z then I suggest for you to get an LTD frame and go from there. Thicker tubes and brace it so you can go back to original stock. Problem fixed.
Just read les's post. WHAT HE SAID!! :laugh: That is exactly what I'd do. Then you can do the bearings in front and brace the frame up and whenever you decide you've had enough back to original with no issues.
lushbaugh wrote: i didnt wanna chop and weld on my frame at first either but it needs it, and i have a 79 ltd which is supposed to have less flex but the frame leaves alot to be desired, head woble at 120 is nasty also so i suspect its not true.
Replied by Kidkawie on topic frame bracing
17 Dec 2012 12:18
I see the steel vs. aluminum debate all the time on MX sites. Aluminum frames are easier and cheaper to build than a steel tube frame. KTM and other Euro makes still build steel frame bikes...and win championships with them.
That's where I'm at with my Z1B. I can't bring myself to brace the frame, so I'm trying to get better handling with tuning and bolt-on stuff. So far I replaced the shocks with ZRX shocks, that alone seemed to help some with the 80mph tank slappers. I still get a weave in high speed sweepers (45+ mph). I plan on installing emulators in the forks along with stiffer springs and a steering stabilizer.
I'm not expecting to turn like I'm riding a ZX6R, but the bike should be alot safer and stable than it is now.
(And yes, for the 1,000th time, the steering and swingarm bearings are new, lol)
toad wrote: My new build will be off a 74 z1, maybe go big block , but was trying to stray from welding on that frame in hopes one day it will be put back to original condition, 7s 150 mph no frame bracing, nice.
Sooo while I wait for info from Wiseco I worked on some other stuff. Forks! I rode the bike with the ZRX shocks for a year or so. I determined the front was too soft to match the rear. The manual calls for 15w oil, 17.4" from top. So I raised the level to 16" and installed a washer-bolt-washer in each leg to act as a preload spacer. This should give me a bit of firming up.
I made this fork tube clamp years ago and it has been super useful. It works on everything from skinny KZ tubes to beefy KTM sliders.
Done!
Attachment ForkAssembly1.jpg not found
Attachment ForkAssembly2.jpg not found
Attachment ForkAssembly3.jpg not found
Done!
Attachment ForkAssembly.jpg not found
Replied by IGO202 on topic Noobie checking in.....
28 Nov 2012 21:11
Thanks guys for the compliments.
I'll answer a few questions posted.
The stacks were on the bike from the last time I rode it, that was at the strip. I always ran K&N pods on the street but the bike picked up quite a bit with the stacks.
The swingarm is not braced, just the base model. I can't remember any model number or anything, sorry but it's been a long time & I'm getting kinda old.
I'll post a picture from the other side & add it to this post if that's okay.
I live at the foot of Deals Gap and set the bike up years ago to ride in the twisties. Besides the wheels and swingarm I installed S&W Street Stroker shocks, fork brace and front springs (can't remember the brand)and the bike did well for what it was back in the day.
I love just about all bikes but lean toward the old school look even though I own a ZX14. I always liked the looks of the ZRX's and found a clean one 7 years ago that I still have. I installed a Turbo-Tec turbo kit six years ago and the bike is a hoot.
Here's a shot of me & momma strolling thru the Dragon.
Dan
Dan
Replied by Haybus on topic 76 KZ900 LTD Streetfighter build
24 Nov 2012 03:23
Yeah, I like the look of duals. Maybe some ZRX shocks. My friend has a ZRX and I've always thought it was good looking.
Alan
Alan
11 Nov 2012 04:07
What, you don't like the pretty blue coils? I bought the bike a couple years ago for my father to ride, but I think he was a bit intimidated because his feet don't touch flat on the ground. Plus he's 74 now and a bit afraid the bike would break him. I took it for a ride when I got it home today and it feels like a hard tail. For sure new shocks will be on the list. I do like the looks of the ZRX shocks with the piggy backs.
yeah if i can find some that wont break the bank
. i just went and talked with the guy that painted the parts. im planning on getting the frame blasted and painted along with painting the motor after the new year.
ThatGPzGuy wrote: Looks good. Now you need some ZRX shocks.
Displaying 271 - 280 out of 677 results.
