Problem with Mikuni Carb Body
- DanMadBoy
- Banned
Re: Problem with Mikuni Carb Body
31 Mar 2023 13:11sorted:Noticed the hex head fastener. Those are a recipe for stripping threads in soft alloys very easily. Float bowl screws don't have to be King Kong tight. If the gasket's not fresh, over-tightening the screws won't help anyway. Suggest a torque screwdriver such as those used in the gunsmith trades.to reduce the likelihood of over-tightening & stripping small hex fasteners in soft metals.
Good Ridin'
slmjim & Z1BEBE
- DanMadBoy
- Banned
01 Apr 2023 08:33 - 02 Apr 2023 13:02Thank you for posting. Btw I'm changing the carb boots on my KZ75.Political comment deleted.
Last edit: 02 Apr 2023 13:02 by KZQ.
- DanMadBoy
- Banned
01 Apr 2023 14:45
Was pretty easy. Didnt even have to totally remove the carbs, just slid them to the side and put the new boots on.
03 Apr 2023 05:06
You should check to ensure no air leaks.
- DanMadBoy
- Banned
03 Apr 2023 05:12 - 03 Apr 2023 05:14You should check to ensure no air leaks.
Thanks for the reminder.
as Ive mentioned two bikes in this post, the carbs of which I speak are on the 650. The 750's i changed the other day had a leak on the manifold side boots. On the 650 the Carb boots on both sides are brand new, engine/cylinder cover are all tight, no leaks. Issue was dried O rings - ethanol related over time.
Carbs were gone through and will go back on the bike when the tank and rear fairing paint are done this week. Cant wait to post a pic in the appropriate area of the forum. These are the carbs off. So pretty I think.
Thanks again for the "leak" reminder
Last edit: 03 Apr 2023 05:14 by DanMadBoy.
- DanMadBoy
- Banned
03 Apr 2023 07:23You should check to ensure no air leaks.
Just double checked again as well. No leaks so Im good.
