1980 KZ1000 LTD shift shaft oil seal part number?
  • Rich K.
  • Rich K.'s Avatar Topic Author
23 Feb 2020 18:40
#819773
I have a 1980 KZ1000 LTD (chain drive) that leaks oil around the gear shift shaft; I am guessing the oil seal in the cover that the shaft goes through is bad. Can someone please tell me what the OEM part number is so I can find a replacement?
  • TexasKZ
  • TexasKZ's Avatar
Re: 1980 KZ1000 LTD shift shaft oil seal part number?
24 Feb 2020 04:33 - 24 Feb 2020 04:47
#819784
It is number 11 in this diagram and still available new from Kawasaki. You will need two of them.
www.partzilla.com/catalog/kawasaki/motor...e-covers-79-80-b3-b4
Last edit: 24 Feb 2020 04:47 by TexasKZ.
The following user(s) said Thank You: Rich K.
  • SWest
  • SWest's Avatar
  • 10 22 2014
24 Feb 2020 07:00
#819791
You'll need three. Two in the sprocket cover and one in the tranny cover.
The following user(s) said Thank You: TexasKZ, Rich K.
  • TexasKZ
  • TexasKZ's Avatar
24 Feb 2020 18:03
#819832
Yes, three, not two.
The following user(s) said Thank You: SWest, Rich K.
