Removing Kickstarter Pedal ?
  • kzdcw
  • kzdcw's Avatar Topic Author
  • 77' KZ1000A
21 May 2017 17:04
#762419
Is there an easier way to remove the kickstarter pedal from my 77' KZ1000A ? When I ride, the end of the rides on the inside of my right calf. That might be part due to me using Dual pod air filter rather than the stock airbag which may kick out the pedal a little.
Anyway bolt removed easy, just the pedal won't slide off the splined shaft even with me trying to gently spreading the pedal at the shaft while tugging at the pedal. I liberally soaked the pedal and shaft area with liquid wrench.
Don't want spread the pedal too much in fear of breaking/cracking it. Anyone have any Better Ideas ?
77' KZ1000A
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: Removing Kickstarter Pedal ?
21 May 2017 17:34
#762422
Kick start should come right off with some wiggling and maybe a little prying with flat bar behind kick starter as long as bolt is removed. .
Mine just slides off so maybe you got some corrosion .
Dave B) B) B)
  • kzdcw
  • 77' KZ1000A
21 May 2017 18:07
#762423
Dave, I'll let it soak with Liquid Wrench for a bit. Bolt removed easily, no signs of corrosion. I know you can spread pedal at bolt a little but didn't want to force it. Haven't figured a way to walk pedal off of shaft yet, maybe some type of puller ?
77' KZ1000A
  • SWest
  • SWest's Avatar
  • 10 22 2014
21 May 2017 18:14
#762425
You can tap a screwdriver in the slit just enough to free it. You just have to be careful.
  • kzdcw
  • 77' KZ1000A
21 May 2017 18:17
#762426
Steve, I'm sure that's a better way than what I was trying to do which was just sticking a large flat blade screwdriver in the slot and twisting the handle by hand while trying to tug at pedal. Not working.
77' KZ1000A
  • Moderator
  • Moderator
21 May 2017 19:28
#762433
Try tapping on the kickstarter next to the spline shaft with a hammer ( Brass or put something on part before hitting to protect the finish.
This may shock the bond enough to release it . I would then wiggle and pry the kickstarter and it should come off.
Dave B) B) B)
  • kzdcw
  • 77' KZ1000A
21 May 2017 19:41 - 21 May 2017 19:42
#762435
Steve, Dave I'll try Both of your ideas in the next day or 2 . Getting late here this evening and got to get ready for work tomorrow. Thanks for the advice !
77' KZ1000A
Last edit: 21 May 2017 19:42 by kzdcw.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
22 May 2017 00:04
#762444
Remove the circlip and pull of the kicker
get the right two arm puller
everything else and unnecessary force destroy your kickstarter cover
Michael
  • kzdcw
  • 77' KZ1000A
22 May 2017 04:08
#762449
The pullers are cool, but I'm just trying to remove the Pedal, not the shaft/gear assembly.
77' KZ1000A
  • TexasKZ
  • TexasKZ's Avatar
22 May 2017 07:30
#762457
So you are trying to remove #10 from #6 in the diagram??
As already mentioned, just remove the e-clip and it should slide off very easily. If not, I would suggest some better penetrant like Kroil or a 50-50 mixture of acetone and atf.
  • SWest
  • SWest's Avatar
  • 10 22 2014
22 May 2017 07:40
#762460
You might try cocking it forward one spline on the shaft so it won't be hitting your leg as much or get a new one. I love my kick starter.
I WANT ONE.:woohoo:
z1parts.net/z1-900-kz900-kz1000-kick-starter-pedal-19mm/
  • kzdcw
  • 77' KZ1000A
22 May 2017 15:59
#762505
Actually I'm trying to remove #6 from the #1 kick shaft . #10 and #6 are still attached .
77' KZ1000A
