Points and timing a KZ650. I'd rather do many other things personally.
Anyway, the way you asked the question, suggests to me that you have little or no experience dealing with point ignitions. So, if I say things that are you already know. Please forgive me. Just trying to help.
One of the first things I would do, although you do not have to, is replace the screws holding the points and the points plates. They are metric, M4 X about 6mm to 8mm long. I found new ones at my local Lowes hardware store that had allen heads instead of phillips heads. They also had ones with a straight slot on them, either will work just fine. From the picture you submitted the screws you have looked pretty yucky, which is pretty normal for these older machines. I had to buy 10mm ones and cut them down to a proper length. I used a dremel cut-off tool. It's a matter of being able to tighten them enough so they hold the points position.
Anyway, pick one side to adjust and using a 17mm wrench (igintion turned OFF) slowly turn the shaft that is sticking out from the points. It will turn the engine over. Watch the gap between the points. This is not an exact science and is not required to be. At about the point in the rotation of the shaft when the gap in these points is the biggest. Stop. It is at this point you will adjust the gap. My 78 KZ650 gap is between .300 and .400 mm. My feeler gauges are standard, but they have the metric size stamped on them also. I pick a feeler gauge that is about .356mm in size. That's about the thickness of a matchbox cover. The next part is more of a pain in the butt than it should be (compared to other point ignition systems). You need to loosen (not remove) the two screws that hold the points to the point plate and move the points around until 1. the roller on the bottom is still in contact with the shaft and 2. the gap between the points is the thickness of your feeler gauge. It's hard to describe it better than that. Look, pay attention and play with it. You will be able to figure out how to do this. Oh, you will want to, either using some sandpaper or a small file, you will want to make the two surfaces smooth and shiny Before you adjust the gap. Don't worry too much about the gap being "perfect" it is not extremely critical that the gap be an exact measurement. That's one reason why they give a range for it to be in. Also, adjusting points is an acquired skill. If you have no experience doing this, it will take time and practice until you can do it well and proficiently. Not to mention that something about the way the KZ650 points are mounted, they are trickier and more difficult to adjust than most points systems. After you have given it your best shoot and have tightened the screws down. I usually turn over the engine a few times and check the gap again. If you need some idea of how 'tight' the feeler gauge should feel between the points try this, stack about 20 sheets of paper. Pull one piece of paper out of the middle. Hold the stack on the end with one hand and slide the other piece of paper in and out with the other hand. That's about the snugness you are looking for. Once agian this isn't exacting science. After you are happy, or at least satisfied, with the one gap. Do the same thing to the other.
Oh yea, you do not need to sand the rust off the spring. Probably better not to mess with them (if it ain't broke, don't fix it).
Hope this helps more than confuses you. BTW, another way to check the gap, and a more accurate way, is to use a dwell meter. However, I'm not going to describe that here. Just know that you can 'electronically' check the point gap for correctness. It isn't any easier to physically adjust them (actually it's tricker to do). But, a dwell meter can give you a measure of the electrical correctness of the gap.
Good Luck!
