rear signal lights
  • krazinite2003
  • krazinite2003's Avatar Topic Author
rear signal lights
04 Aug 2009 05:39
#311461
hey guys ive got an 83 KZ750L3 this bike was given to me in boxes have put it together have ridin it a couple times
all the lights did work up untill a couple days ago i went to ride it to the store a couple days ago and found that the rear signal lights no longer work turn signal work but
well put it this way when i turn on the ignition on all lights should light up right well the head light will front signals will and tail light will but not the rear signal but if i use the turn signal switch both lights will blink i hope this makes sence fuses are fine was well
i have two 1983 kz750 L3
  • Locozuna
  • Locozuna's Avatar
Re: rear signal lights
04 Aug 2009 05:59
#311464
I think what you are saying is you want rear running lights. While your front blinkers are used for running lights I do not believe your rears are supposed to be. I could be wrong here. The easiest way to check is to take off the lens and see if they are double filament. One for running lights and one for blinkers. Like I said I could be wrong. But I don't remember many with rear running lights.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
  • JMKZHI
  • JMKZHI's Avatar
04 Aug 2009 05:59
#311465
The rear turn signals are only used as turn indicators.
The fronts serve as running lites & turn indicators.
  • MFolks
  • MFolks's Avatar
04 Aug 2009 11:01
#311504
Most states do not allow rear running lights unless RED lenses are used. To verify light functions, the front signals will have three wires(running filament,turn signal filament, and ground wire) while the rear signals will have two wires(turn signal filament,and ground.
  • bountyhunter
  • bountyhunter's Avatar
04 Aug 2009 15:18 - 04 Aug 2009 15:21
#311550
True, at least in this state. I installed front units in the rear so I could use the rear turn signals for brake/running lights so I painted the lenses red to comply. Rear turn signals can be red or amber, but running lights in the rear have to be red.
Kawi did make some red lenses for the police bikes that fit the stock turn signals, but I don't know if they still sell them.
Last edit: 04 Aug 2009 15:21 by bountyhunter.
  • MFolks
  • MFolks's Avatar
04 Aug 2009 16:55
#311579
Maybe clear lenses with red bulbs as running and turn signals is what you need. Look at this website:
www.kandstech.com/index.php?page=Turnsignal
  • krazinite2003
05 Aug 2009 04:50
#311695
i guess i should have said im up in canada sorry i just thought that the rear signals lit up when you turned on the ignition switch icould have sworn they did lite up
  • krazinite2003
05 Aug 2009 04:52
#311696
oh and how fast are they suposed to flash
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
05 Aug 2009 05:10
#311698
I have used LTD front blinkers in the rear.
  • Locozuna
  • Locozuna's Avatar
05 Aug 2009 05:16
#311699
My rear blinkers are red on both the 77 650 and the 76 900. Guess bro did that then. Don't look painted. He must have bought them somewhere. I'd guess e-bay. Not runnin' lights.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
  • bountyhunter
05 Aug 2009 14:12 - 05 Aug 2009 14:14
#311804
I have seen the red turn signal lenses for sale on ebay. I remember they were like $30 for a set of two. I looked the new OEM part price up on babbitts and it was like $6 each (they are the front lenses for the position lights on the cop bikes). Didn't try to order any, I just painted mine.
Last edit: 05 Aug 2009 14:14 by bountyhunter.
  • bountyhunter
05 Aug 2009 14:13
#311805
Ballpark of about a second, I think mine is 0.8 seconds so it will flash about 6 times in five seconds.
