Reserve Lighting Switch
  • grumpy56
  • grumpy56's Avatar Topic Author
28 Jun 2009 06:36
#302657
Good morning. Any suggestions regarding how to troubleshoot a reserve lighting switch on a 1000J? My "problem" consists of a very dim low beam, the warning light indicating a lighting problem "on", and a high beam warning light that does not function. Tried a new bulb and the shop manual addresses certain scenarios, but not this one. Also, anyone know a source for the reserve lighting switch? My shop manual indicates that it is the brown six pin connector, but pics I've seen of a few on e-bay look like they have a white connector. Thanks.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
  • otakar
  • otakar's Avatar
Re: Reserve Lighting Switch
28 Jun 2009 06:50 - 28 Jun 2009 06:50
#302659
I just bypassed mine since I installed a HID, Xenon lighting system on the bike. The reserve lighting switch is there only if the low beam burns out then the Hi-Beam turns on at about 6V. I just looked at the weiring diagram and rewired it like one of the ons that do not use the RLS. Not all models have one.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 28 Jun 2009 06:50 by otakar.
  • grumpy56
28 Jun 2009 09:12
#302696
Thanks otakar. May need to do that if I can't figure this out.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
  • otakar
  • otakar's Avatar
28 Jun 2009 14:40
#302800
The reason there is a brown and a white connector is because there is a jumper in between. The one on the unit itself is white. Did you try to change both bulbs, the hi-beam warning bulb and the main headlight bulb?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • grumpy56
28 Jun 2009 17:46
#302858
No, didn't check/change the hi-beam warning bulb. Will do that anad see what happens. Gracias.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
  • otakar
  • otakar's Avatar
28 Jun 2009 18:22
#302868
Always check all the related bulbs first. Headlight and warning and indicator.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • ww2willys
  • ww2willys's Avatar
01 Jul 2009 19:02
#303730
otakar, could you please post a diagram of how you bypassed the reserve lighting device? I just installed a HID light and am trying to get the failure light to go out. Thanks!!
  • otakar
  • otakar's Avatar
02 Jul 2009 06:50
#303840
When I get back home on Tuesday I will redraw the diagram and post it.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • ww2willys
02 Jul 2009 19:00
#303976
Thank you otakar, will be looking forward to seeing the diagram.
  • grumpy56
02 Jul 2009 22:02
#304031
I found a NOS reserve lighting switch on e-bay and hopefully will have it in a few days. Hope that is the source of my problem as I'd like to keep the stock setup.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
  • grumpy56
03 Jul 2009 15:41
#304196
Checked everything and I believe my reserve lighting unit is shot. When I bypass it, everything seems to work fine. The unit is located on the front of the battery box below the air cleaner. I assume I have to remove the battery box to get to it. Any other suggestions as I am one lazy old coot? Thanks.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
  • otakar
  • otakar's Avatar
03 Jul 2009 15:49
#304197
That is the only way I know of. It is very uncommon for one of those to go bad.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
