Mega squirt users
- SQLGuy
Re: Mega squirt users
28 Dec 2008 20:50
Wow, 1500 degrees is really high... like propane torch hot.
Did he give you a calibration curve with them, or did you have to do your own heating and measuring?
FWIW, I found a fair amount of discussion about head temp versus oil temp on a Porsche air cooled FI site. Their conclusions seemed to be that oil changed too slow but that head temp changed too fast, so it was a bit of take your pick and pick your enrichment and IAC points accordingly.
'82 SECA 750 - converted to fuel injection with Microsquirt and a bunch of home-made pieces.
'83 GPz 750 - mostly stock... so far
Project page: residentialcolorado.com/SECA_750i.htm
- gmannz1
17 Jan 2009 18:58
I've got a KZ1000G Z1 Classic I'm want to put a megasquirt in, the original ECU died, so I'm a megasquirt newbie. I would like to keep as much original equipment as possible, injectors, airflow meter, throttle switch, temp sensor. I know I will need to adjust the fuel tables, but is there anywhere I might find an existing table to at least start from.
thanks
thanks
1975 Z1B
1975 KZ400
1980 KZ750 twin
1980 KZ1000G
1975 KZ400
1980 KZ750 twin
1980 KZ1000G
- steell
17 Jan 2009 19:18
Keeping the airflow meter increases the difficulty, be a lot better to remove it and go hybrid Alpha N/speed Density. I think you will need to replace the throttle switch with a TPS also.
Shortcuts pretty well suck, you'd be a lot better off to follow the manual and make your own map.
- MFolks
17 Jan 2009 19:18
I'm not sure if you have these websites:
1. www.msefi.com
2. www.dropbears.com
3. www.dobeckperformance.com
4. www.witchhunter.com (fuel injector service)
1. www.msefi.com
