ic ignitor
  • xrannie
  • xrannie's Avatar Topic Author
ic ignitor
09 Jul 2007 04:26
#155602
hi people. i just bought my first street bike- 79kz1000 mkII. ran fine for about a week. started it yesterday morning. it ran for about 10 seconds and quit, won't start back. believe it is the ic ignitor box. anyone have a spare for sale? nashville area. thanks for reading-
  • Nephlyte
  • Nephlyte's Avatar
  • To do what is right is to know what you want.
Re: ic ignitor
10 Jul 2007 13:23
#155991
are you sure its the igniter?
It cranks and does not start? Is there no spark? Did you check connections between the electronic pick up/IC module/coils?
I thought i had the same problem on my MKII, but it turned out that i'm just bad at wiring and soldering your wires is a good idea.
1979 KZ1000 MKII, 1075 wiseco kit installed, 10.25:1 compression, welded crank, kerker header and custom paint.
  • loudhvx
  • loudhvx's Avatar
Re: ic ignitor
10 Jul 2007 17:55
#156026
If it is the igniter, you could try this:
www.geocities.com/loudgpz/GPZgmHEImod.html
I'm think the early gpz550 igniter is compatible with the early KZ1000 pickups, but I'm not positive.
  • wagonmaster69
  • wagonmaster69's Avatar
  • 78 KZ1000A2 / 82 KZ1100 Spectre
Re: ic ignitor
11 Jul 2007 22:02
#156291
So It should work on a 78 KZ1000 A2 also?
  • loudhvx
  • loudhvx's Avatar
Re: ic ignitor
12 Jul 2007 08:16
#156371
I thought the 78 was points. Kawasaki shows points for the 78 1000 A2. But someone may have put electronic on it.
The pickup units (59026-1012) with mechanical advance are the ones that work. The HEI mod won't work on the electronic advance models.
  • wagonmaster69
Re: ic ignitor
12 Jul 2007 12:08
#156441
OK now I know. And knowing is is is aww sh:pinch:t what ever now I know. Thanks loudhvx.
  • EDMIII
  • EDMIII's Avatar
Re: ic ignitor
12 Jul 2007 20:41
#156531
Speaking of ignitors, I have an 88 EX500 and I started testing the ignitor based on the service manual. Instead of 400k Ohms, I'm getting 1.6 meg. Since I'm new at this should I take the service manual as the last word on this? BTW the symptoms are hard starting (only once in a while - accompanied by a backfire) and have lost all power with the tach going crazy on more then one occasion. Other times runs like a charm. Thx.
  • AK82kz440
  • AK82kz440's Avatar
Re: ic ignitor
14 Jul 2007 13:32
#156810
Make sure it's the igniter. I had the same symptoms, ran good stopped mid ride, engine turned power to everything but no spark. I began trying to backtrack went to either igniter or coil. Pulled coil went to Auto-electric specialist had them bench test the coil. They told me to start shopping for a coil. Coils aren't as expensive and will go out more often than an igniter per a mechanic at the dealership (he also recommended that I purchase any coil in the 2-3 ohms range and jerry-rig it in because that is what they used to do years ago). I don't think he was trying to sell me parts. If you are not sure how to test the coil and igniter look through the other posts, or someone will provide a link to the post.
  • xrannie
Re: ic ignitor
17 Jul 2007 09:48
#157424
o my gosh. thanks bunches for all the good advise/tips.
anyone know if a points set up from kz550 or something like that will work? ( by the way, i'm no mechanic, just the info digger!! ) so many good suggestions/tips here. not like all the tuner forum bull... i'm used to.
  • xrannie
Re: ic ignitor
17 Jul 2007 09:51
#157426
btw. what happened was i started it one evening last week after riding it a few times. it ran/idled fine, just quit, no fire. nada! i'll get him to read what you said and we'll try from there. that ignitor is high priced for a new one!!!
  • loudhvx
  • loudhvx's Avatar
Re: ic ignitor
17 Jul 2007 10:39
#157444
Last time I checked, Kawsaki wanted $500 for an igniter. You could get an aftermarket one for just over $100. The one I built costs around $40.
  • EDMIII
  • EDMIII's Avatar
Re: ic ignitor
17 Jul 2007 10:41
#157447
Do you have any information on AfterMarket or how to build one for an 88 EX500? Thx.
