KZ 650 Will run perfectly until it hits 6000 rpm
Re: KZ 650 Will run perfectly until it hits 6000 rpm
29 May 2011 12:22Attachment picpostnewsite.jpg not found
- wyliewix
29 May 2011 12:32
Many thanks for all your imput Guys,
Have had a play with air box pipes, so gonna have a cuppa and give it a go. I'll let you know how it went. If still not right will take petcock off tomorrow.
Thanks all again.
Thanks all again.
29 May 2011 12:37wyliewix wrote: ...Haven't thought of fuel cap vent so will give that a try...Haven't checked fuel tap yet as being tight I am waiting for tank to run low!....
When necessary to drain the fuel tank, may do so by removing the existing fuel hose from petcock and connecting another length of hose to the petcock, and then drain the tank into a gas can.
- loudhvx
29 May 2011 14:54
Electrical can also have a similar dead spot, that actually acts like using a kill-switch.
If the coils are bad, or if the plug gap is too wide, or if the advancer is stuck, you can get those exact symptoms... fine until large throttle opening under load, then cuts off until throttle is closed downward.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- wyliewix
04 Jun 2011 07:56
Hi,
Just to update on this running problem, which is now sorted, running well and revs all the way out.:evil: Turned out it was the jets, and it was actually over jetted! Still kept me amused for the week I guess! So god knows what the previous owner was thinking!
Once again many thanks for all your input.
