carb leak at T
- murr50
carb leak at T
22 May 2011 13:29
hello, my carbs are leaking gas at the T section from the gas tank. I thought i read somewhere a long time ago that there is a quick fix for this using teflon tape or something.. i cant seem to find the thread. has anyone fixed this problem before?
1977 kz650 C
Re: carb leak at T
22 May 2011 14:15
I've also read that shrink tubing works. If mine was leaking I would just replace it while I had the carbs separated Z1E sells replacements. Ed
- moneypit
Re: carb leak at T
22 May 2011 15:36
Heres a link to what I had done. But as 650 ED said if you have them apart replace with new I happened to be in a hurry and Im cheap :lol:
kzrider.com/forum/21-tools/326051-fix-for-shrunken-fuel-pipes
2-76 kz900
St Paul MN
St Paul MN
- murr50
Re: carb leak at T
22 May 2011 17:41
thanks for the tips. i ended up using gas rated teflon tape. sealed up just fine while i wait for a replacement
1977 kz650 C
