BS34 Carbs on a KZ650 with VM's
  • Darkangel
  • Darkangel's Avatar Topic Author
20 May 2011 01:46
#452304
Ok so I have my KZ1100 that has a set of BS34. I was curious would the BS34 increase the power of my 650, if so what all would i need to do to fit them on my bike. It looks as if the rubbers for the Vms are much smaller than that of the 34's to are the rubbers interchangeable? or not?
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
  • wireman
  • wireman's Avatar
Re: BS34 Carbs on a KZ650 with VM's
20 May 2011 01:50
#452305
if your 650 has vm24s on it now the ports would be way to small to take advantage of a carb that big,a set of vm26s would wake it up B)
  • Darkangel
20 May 2011 02:01
#452309
I've read other places where they have swapped bs34 on a 650 with Vm24, with the boots fit on my bike then? that's the only way i can see that happening
  • wireman
  • wireman's Avatar
20 May 2011 02:17
#452314
youd have to slot the mounting holes on the 34 boots would be my guess.
look at the size of the ports on your stock 650 head compared to the bs34 carbs B)
the newer 650/750s have bigger ports to run the bigger carbs B)
  • Darkangel
20 May 2011 02:37
#452318
those buttholes i was going to put those bs34 on my bike...So in other words i would have to change the head for the size change in the intake manifolds?
  • wireman
  • wireman's Avatar
20 May 2011 04:37
#452326
its the size of the carbs thats the biggest issue,it would be a lot easierto just swap the 34s for a set of 26s with somebody B)
