air/fuel
- jacksdad
- 1979 kz 750 OUCH, IT SPARKED
air/fuel
15 May 2011 00:34
so today I went for about a 10 mile ride to my son's baseball game, went pretty well, until i ran out of gas, (i gotta get used to no gas guage), when i got home, before turning off the motor, i played with the air/fuel mixture screws, i think they are also called pilot screws, to see if things would change, as i slowly turned the screws, absolutely onothing changed with regard to the rpm's same thing on the other carb, anybody got any idea what this is all about, the bike rides pretty well at 55-60, but when i hit a small hill, i have to downshift to not loose to much speed on the fourlane, i was thinking that maybe adjusting the air/fuel mix mightmake it better, but as i said, turning the screws did diddy to change rpm's, thanks in advance. :whistle: oh yeah it is a 1979 kz 750 two cylinder, bone stock
1979 kz750 twin cyl.
Re: air/fuel
15 May 2011 00:59jacksdad wrote: ...ran out of gas....
Should run with petcock set in ON position which allows switching to RES (reserve) position when fuel level gets low. Then it's time to fill up.
Including information about bike year and model in your signature will automatically appear in all posts, past and future.
And may be changed as often as desired.
- jacksdad
Re: air/fuel
15 May 2011 01:07
no worries, thanks for the info on the signature. i just changed it
- jacksdad
Re: air/fuel
15 May 2011 23:38
SO WAHT DO YA'LL THINK ABOUT THE AIR/FUEL MIX?
- TeK9iNe
- What did you do!?!
Re: air/fuel
15 May 2011 23:52
Changing the air fuel mixture screws only affects the idle mixture, and barely the cruise position of the throttle, everything after that (accelleration), uses different parts of the carburetors.
The mixture screws should be set at specific points with calibration equipment like a colortune plug, or a vacuum guage, etc.
If everything is stock on your bike (intake/exhaust), then set your screws back to stock (around 1-1/2 turns out from lightly seated), and be done with them.
To get more power out of your machine, you'll need to start reading up on tuning: Jetting, timing, plug temp, etc.
Good luck.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- dshelly
Re: air/fuel
15 May 2011 23:52
It won't change the idle, just richens the mixture. after adjusting go for a ride and check your plugs to see how they are burning. You want a light tan color.
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- jacksdad
Re: air/fuel
15 May 2011 23:58
oh well, i guess i learned something today after all, i will pull the plugs tommorow to see what they look like, thanks guys
- TeK9iNe
Re: air/fuel
15 May 2011 23:59dshelly wrote: It won't change the idle, just richens the mixture. after adjusting go for a ride and check your plugs to see how they are burning. You want a light tan color.
:blink: It can affect the idle greatly. In order to check that particular carburetor circuit you would require a proper plug chop after many miles of cruising ONLY, and light tan is not what you're looking for from that throttle position.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
