1975 KZ400 - Petcock Replacement?
  • madmatt1
  • madmatt1's Avatar Topic Author
  • Away
13 May 2011 13:48
#450717
So my newly aquired KZ400 has a leaky petcock that someone has globbed up a bunch of JB
Weld or something of that nature on in a poor attempt to fix it. I have a new Honda
petcock that is identical save for the outlet positions- no biggie there. My question is-
how the heck do you change the thing?
1977 KZ1000 LTD
1979 KZ1000 LTD
1978 KZ1000A
  • Proxy
  • Proxy's Avatar
  • 80% Human 20% Nuts/Bolts
Re: 1975 KZ400 - Petcock Replacement?
13 May 2011 13:53
#450719
2 bolts. Unless it's a single pip threaded petcock. If you can't see the bolts I would guess they jbwelded the bolts. Sounds like a real hack job. You need to get the jb off and get the bolts out. Can you supply a picture of where the petcock attaches to the tank? Might help with suggestions as to how to fix it.
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
  • madmatt1
  • Away
13 May 2011 14:07
#450724
It's not the threaded type, that's the only type I've ever changed. What I'm seeing here is that there is a removable (sediment?) bowl on the bottom of the petcock...the one on the bike has been Jb'd on and therefore doesn't look like a removable part anymore. I'm guessing that comes off and
there lies the screws?
1977 KZ1000 LTD
1979 KZ1000 LTD
1978 KZ1000A
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
13 May 2011 14:42
#450727
Looks like you need to remove the sediment bowl. I guess Honda uses the same one: cgi.ebay.com/ebaymotors/HONDA-CB500-CB75...fPartsQ5fAccessories
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • Proxy
  • Proxy's Avatar
13 May 2011 15:50
#450736
Yep it looks like the bown had to come off to access the bolts
cdn2.iofferphoto.com/img/item/192/497/012/F0VP.jpg
