single carb conversion
  • dkshadow
  • dkshadow's Avatar Topic Author
10 May 2011 20:02
#450158
OK mybe this is on here somewere but got tired of looking. I want 1 carb, I have a carb off a Sportster 883 Id liked to put on my 80 KZ1000 Shaft. Any ideas on the intake?
Ride Till You Rot
  • The Milkman
  • The Milkman's Avatar
Re: single carb conversion
10 May 2011 21:44
#450188
6 years ago I make a manifold out of 1 inch copper tubing that fit right into the carb boots on my 650 and have been riding it ever since. I used a Zenith Stromberg carb from an Austin Healy though. The pics for it were in the forum archive. But, I can't find the archive here. I'll see if I can find them on my computer and repost them.
Les
  • loudhvx
  • loudhvx's Avatar
11 May 2011 11:06 - 11 May 2011 11:08
#450283
I remember it well.
Some nice plumbing work. Here's the link:
kzrider.com/forum/3-carburetor/50995-z1-single-carb-mod
Last edit: 11 May 2011 11:08 by loudhvx.
  • wireman
  • wireman's Avatar
11 May 2011 13:51
#450307
here mr turbo did all the engineering for you you to run your kz1000 with a single carb! :woohoo:
Attachment mrturbo.jpg not found
  • KruZer
  • KruZer's Avatar
11 May 2011 17:45
#450339
Easy to fab a manifold out of round aluminum tubing. I had a manifold made a few years ago to run a 40mm Weber carb on my KZ900. It worked so well that I had another manifold made to run dual 40mm Webers on my dragbike. I still have the manifold for the single Weber somewhere in the garage. If I can find the manifold I'll post a picture in the next few days.
Buzz
*1977 1000, 1975 KZ998 LSR bike.
  • dkshadow
11 May 2011 21:17
#450380
are there considerable power gains or anything going to one carb? I was just thinking of less tunning.
Ride Till You Rot
  • The Milkman
12 May 2011 08:12
#450455
Like I said, I did mine for less tuning too.
I'm not going to call it "power", but I picked up a "smoothness" in the running of the engine that gives it better acceleration in lower speeds than it had before. In my mind I attribute that to all 4 cylinders getting that same mixture all the time.
Les
  • baldy110
  • baldy110's Avatar
13 May 2011 13:46
#450716
kawasaki engineered these engines to run on 4 carbs. With 1 carb you are going to lose performance. At small throttle openings it will probably be smoother but you will lose performance.
