I'm gettin there. Carb overflowing though. HELP!!
- rdk
10 May 2011 00:41
Man I have done everything you guys have said to do and my 78 kz650 is running NICE. However. I noticed as bike was turned off and on kick stand a few of overflow hoses were leaking a good amount of gas? Dirty floats? I just put tank back on. Haven't dipped it yet. Also put new bars on. I think I need new throttle cables. Could cable be pinched causing throttle to stay open and cause bowls to fill up?
- slittl26
- 1977 kz650c
Re: I'm gettin there. Carb overflowing though. HELP!!
10 May 2011 07:29
your floats if set right should stop too much fuel from getting into the carb have you done a fuel level check also make sure you turn your petcock off if its bad can let fuel keep running
10 May 2011 07:41 - 10 May 2011 07:43rdk wrote: Man I have done everything you guys have said to do and my 78 kz650 is running NICE. However. I noticed as bike was turned off and on kick stand a few of overflow hoses were leaking a good amount of gas? Dirty floats? I just put tank back on. Haven't dipped it yet. Also put new bars on. I think I need new throttle cables. Could cable be pinched causing throttle to stay open and cause bowls to fill up?
Could cable be pinched causing throttle to stay open and cause bowls to fill up? --- Imo, that's not the problem.
Dirty floats? --- One likely cause (amongst several other possible causes.)
Would also consider float malfunction for whatever reason (such as damaged, bent, sticking, leaking,etc.)
And possibility of cracked overflow tube.
Last edit: 10 May 2011 07:43 by Patton.
10 May 2011 07:46
Could try running some SeaFoam in the fuel, which might help clear any crud that's interfering with proper operation of the float valves.
The following user(s) said Thank You: rdk
10 May 2011 07:55 - 10 May 2011 07:55
Probably dirty float valves. The good news is you can drop the bowls and clean the valve orifices and needles without removing carbs. Use a q-tip and carb cleaner; use nothing abrasive! Ed
Last edit: 10 May 2011 07:55 by 650ed.
- donthekawguy
10 May 2011 11:45650ed wrote: Probably dirty float valves. The good news is you can drop the bowls and clean the valve orifices and needles without removing carbs. Use a q-tip and carb cleaner; use nothing abrasive! Ed
What I used to do is hold a clean white cloth under the carb with the bowl off, turn the gas on and see if any gunk comes out. You will see it in the cloth. And put a in line filter in and you should be good.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
