New Petcock Problems
  • badrhino
  • badrhino's Avatar Topic Author
09 May 2011 18:30
#449899
So i bought a new petcock to replace the old one on the tank. Try to take the old one out and the damn screw heads are wanting to strip out. How can I get these out? And why do they make phillips style heads on applications like that when a normal bolt type head would be way better and would not round off?
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
  • JakeB
  • JakeB's Avatar
Re: New Petcock Problems
09 May 2011 20:14
#449926
Get yourself an impact driver like this
www.harborfreight.com/impact-screwdriver...with-case-37530.html
They are the best thing to use for stubborn phillips heads.
Other than that you can try to grab it with vice grips or grind a new slot in it (I have never had luck with the slot method), but I would just put some penetrating oil on it and let it soak until you get an impact driver.
1978 Z1-R
  • hocbj23
  • hocbj23's Avatar
09 May 2011 21:21
#449935
Clearance issues with bolt head.
  • badrhino
09 May 2011 22:15
#449947
Thanks...That's what I've been looking for but couldn't remember what they were called.:S
Franken Z!
  • JR
  • JR's Avatar
09 May 2011 22:37
#449956
I have a set of these
www.smarthome.com/89090/GRABIT-3-Piece-Drill-Set-PR-5823/p.aspx
which are also great for removing stripped screws.
I think Sears sell them under a different name.
An impact driver is also a must have for working on these old bikes.
  • mjg15
  • mjg15's Avatar
09 May 2011 22:44
#449957
The "phillips" arent really phillips, I think that they are JIS. If you grind the pointy tip off of a #2 phillips they wont strip (usually)
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
