late model 29mm smoothbores
  • toad
  • toad's Avatar Topic Author
06 May 2011 01:55 - 21 May 2011 08:06
#449161
can anyone tell me the difference between early and late model 29mm smoothbores .jetting advice specified 20 pilot or 25 pilot for late model .How can I tell which model I have?
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
Last edit: 21 May 2011 08:06 by toad.
  • toad
Re: late model 29mm smoothbores
21 May 2011 08:09
#452528
does anybody know?
thanks
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
  • peter1958
  • peter1958's Avatar
21 May 2011 08:42
#452531
29mm smoothbores Z1 / KZ900 / KZ1000
Main Jet 120
Air Jet 0.9
Needle Jet O-6
Jet Needle 5DL31-3
Throttle valve (slide) 1.5mm cutaway
Pilot Jet 17.5 or 20.0 (or 25 in the later versions)
Air Screw setting 1 1/2 turns out
29mm smoothbores CB750
Main Jet 115
Air Jet 0.9
Needle Jet O-6
Jet Needle 5DL31-3
29mm smoothbores KZ650
Main Jet 105
Air Jet 0.9
Needle Jet O-4
Jet Needle 5DL31-3
Pilot Jet 15
New, New, New!
Honda
Kawasaki
Suzuki
Yamaha
Parts by Brand
Browse parts by Brand
Parts by Model
Honda
Kawasaki
Suzuki
Yamaha
Parts by Category
Honda
Kawasaki
Suzuki
Yamaha
FASTENERS
Metric Fasteners
Reference Info
Site Guide
Kawasaki
Maintenance
Spark Plug Guide
Useful Links
Payment by
accepted here
  • peter1958
  • toad
23 May 2011 09:24
#452981
do you see where it says in brackets (or 25 in the later versions) that is what I am trying to explain; appreciate the feedback likewise.
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
  • testarossa
  • testarossa's Avatar
23 May 2011 09:43
#452983
Toad, what that is referring to is just the pilot jet size. I'm not sure if there is any difference in the actual carburetor body in later versions. I only have one set myself. The pilot jets can be swapped out to suit your setup. Are you trying to determine what pilot jets should be in the carbs as stock or are you just trying to jet for your particular bike? Personally, #25 pilot jets seem awfully large for a regular KZ1000 motor. I live at sea level in Houston, and I need either a #15 or #17.5 for my setup to run right. Verified AFR with wideband O2 sensor for accuracy. I am running the #15s right now, but could probably use the #17.5s during winter when it's cooler.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • mtkawboy
  • mtkawboy's Avatar
23 May 2011 19:28
#453085
I use the 20s on a built 1105
  • toad
26 May 2011 09:23
#453683
thanks I will try a set of 117.5 and see if that helps!
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
