cv 34 question
- bigkzfan
- if grandpa had tits he"d be grandma, if
cv 34 question
06 May 2011 00:37
can anyone tell me when you take the float bowl off under the bowl gasket what is the circular piece with the rubber washer on top? cv34 carbs
hello, i own a 1982 kz1000 j model with a 4into1 header and factory air box...
- wireman
Re: cv 34 question
06 May 2011 02:29 - 06 May 2011 02:30Attachment bs34.gif not found
are you talking about the slide/diaphragm under the carb top?
Last edit: 06 May 2011 02:30 by wireman.
- Motor Head
Re: cv 34 question
06 May 2011 09:48
I think he means the small rubber gasket that goes right at the float bowl gasket, sealing off the bottom of the small alloy plug. It would be #11009 in the picture, part #11009-1240 GASKET,CARB. PLUG. Then the plug, which also has an O-ring on it I believe, #92066B in the picture, and part #92066-1086 PLUG,CARBURETOR. If it doesn't seal well, it would be able to draw from the float bowl.
- bigkzfan
Re: cv 34 question
06 May 2011 17:38
yes thats exactly what i speak of....
- bigkzfan
Re: cv 34 question
06 May 2011 17:40
why does it have a rubber gasket covering it when the float bowl gasket covers it?
- bigkzfan
Re: cv 34 question
07 May 2011 11:10
would it cause a fuel delivery issue if the rubber gasket on top of the plug was missing???
- Motor Head
Re: cv 34 question
08 May 2011 20:52
If missing you can make 1 easily, gasket material or an O-ring works good.
