Rejetted and needled carbs now sync needed??
- Omaha Rider
04 May 2011 23:44 - 04 May 2011 23:45
I rejetted the carbs on my 78 kz650 D to 17.5 for the pilot and 110 mains, and moved the needle clip down one for 4-1 streight header and pods. Do I need to Sync the carbs now? I've been told that I do, but I don't see why? They should be the same as before. What would have changed? Thanks
1978 KZ650 SR D
Last edit: 04 May 2011 23:45 by Omaha Rider.
- Nebr_Rex
Re: Rejetted and needled carbs now sync needed??
05 May 2011 00:12
If it ran fine before you should be ok,but,it would not hurt to make sur everything is right on the money.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Omaha Rider
05 May 2011 00:16
I pulled the slides to get to the needles. Is there a way to sync them without paying $60-80 dollars?
1978 KZ650 SR D
05 May 2011 00:27Omaha Rider wrote: I rejetted the carbs on my 78 kz650 D to 17.5 for the pilot and 110 mains, and moved the needle clip down one for 4-1 streight header and pods. Do I need to Sync the carbs now? I've been told that I do, but I don't see why? They should be the same as before. What would have changed? Thanks
The throttle slide heights will likely have remained the same, but imo that condition doesn't assure equivalent continuing sync properties following the changes.
Am thinking change in pilot circuit alone (larger pilot jets) might require re-sync, never mind cumulative effect when also changing intake (pods) and exhaust (4>1) on performance of pilot circuit.
Performance of each cylinder at idle and lower rpm may react differently to the changes.
Would hook up the sync gauges and take a look.
A slow steady even idle with minimal cam chain noise, and strong pull away, usually indicates a pretty close sync.
- loudhvx
05 May 2011 11:43
In the last two years or so I've rejetted and adjusted needles over a dozen times on several sets of carbs while doing o2 sensor experiments. Every time I would check the carb sync and it was always off if I did anything with the top ends of the carbs or if I removed the carb rack. I sometimes change the main or pilot jets without removing the carbs, in that case the sync usually stayed the same.
You can screw up the sync if you just grab the carbs and wiggle them around a bit. I've seen the differential go from 0 cm difference to over 2 cm difference by twisting the rack the wrong way. (And Ive seen it on 650's and 1000's as well as many 550's.)
It's best to give it some hard rev snaps to let the carbs settle in position, then do a final sync with disturbing the carbs as little as possible.
Here are some notes on manometers:
home.comcast.net/~loudgpz/GPZweb/Manomet...meterNotes.html[/url
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
