will a kz 650 carb fit a kz750 around the 1980's
- kzrebuilder2010
02 May 2011 15:06
I am trying to find out I have a 1980 KZ750 and a gentlemen is selling a kz 650 around the same year not sure exactly and I am wondering I can use the carb off of that bike on the kz750 or if anyone knows where I can get a used kz750 carb from thanks
I am new to kawasaki
kzrebuilder2010
kzrebuilder2010
- wireman
Re: will a kz 650 carb fit a kz750 around the 1980's
02 May 2011 15:24
depends on which 650 it is,some came with 24s with the ribbed bodies.
others came with bs34 style carbs which should be big enough depending on which 750 it is,might need rejetting of course
- trianglelaguna
02 May 2011 15:25
most folks want the 750 stuff for a 650 to bump up....but the answer is...yes...al four cylinder kz650 and kz 750....ltd....csr.....early gpz.....are super clsoe in cases and parts..alternators are different and can then be swapped from one to the other to fit the bike/elec/harness the said engine is being donated too......
the 750 motor bolts right into the 650 and vise versa.....not shaft driven or later gpz though...all 4 cyl 650 750 will swap
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
Last edit: 13 Feb 2013 13:27 by martin_csr.
- Nebr_Rex
02 May 2011 21:03martin_csr wrote: I'm pretty sure you can put VM24 carbs on a 750-4, but you'll need the carb holders from the 650.
Also, you'll need the airbox ducts from an 81 650-CSR (new CSR ducts are NLA).
BS32s might be a direct fit.
+1
I have a KZ650sr with a 738cc lump,650 24mm carbs and a mac pipe.
Haven't ridden it for a few years,but if memory serves me right,throttle response is better and you lose a little top end r.p.m..
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- roy-b-boy-b
02 May 2011 21:23
I have two sets of 24's and one set of k+n air filters and boots for the intake. 100 bucks and I pay shipping in u.s.
Welcome.
Welcome.
