whats size cabs
  • fstnv1
  • fstnv1's Avatar Topic Author
whats size cabs
02 May 2011 09:33
#448233
I got a 77 kz1000 ltd and was wanting a different set of carbs my buddy told me to put a set of flat slides on it . What size do I use . The bike has a header and iam to install electronic in . This weekend thanks
  • wireman
  • wireman's Avatar
Re: whats size cabs
02 May 2011 09:50
#448234
a set of 28mm carbs from a 79-80 1000 would be a good upgrade,and it would be cheap.
if you want to spend $700.00 and change a set of 29mm keihen cr specials would wake it up nicely,a small motor like that with a small port stock head and stock cams can only move so much air. B)
  • DoubleDub
  • DoubleDub's Avatar
Re: whats size cabs
02 May 2011 13:40
#448272
Interpreting here....
Unless you have your head ported and probably drop in larger cams the flat slides are likely too large for the motor (pretty sure 34mm is the smallest they come in) which will likely greatly impact the low end performance in a negative way.
Sound right Wireman?
  • wireman
  • wireman's Avatar
Re: whats size cabs
02 May 2011 14:50
#448296
pretty much sums it up B)
  • trianglelaguna
  • trianglelaguna's Avatar
Re: whats size cabs
02 May 2011 14:56
#448298
you could wait and watch(along with a few thou other watchers) for a set of old school 29 mm smooth bores......they are around 24-7 these days on ebay and some go as low as 550...i got a set for 275 once and other get em on c-list junkers included in the parts bike...check the classifieds here.......
or get some 28 mm pumper carbs and deal with all the crap they cause imo....either way
the 29 mm will wake that bike up big time and 700-800 for a set of new cr specials 29 is really not much if you plan on this being your bike for years to come....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • wireman
  • wireman's Avatar
Re: whats size cabs
02 May 2011 15:05
#448303
trianglelaguna wrote: you could wait and watch(along with a few thou other watchers) for a set of old school 29 mm smooth bores......they are around 24-7 these days on ebay and some go as low as 550...i got a set for 275 once and other get em on c-list junkers included in the parts bike...check the classifieds here.......
you just cant work on them ya big ol shrek stunt double! :woohoo:
