Carburetor and engine vacuum system question b1
- gumby prichard
01 May 2011 00:09
OK i ran into a huge problem i believe. i have a 78 kz400 b1. I want to put cone filters on my dual carbs. Problem is, i believe the vacuum hose on top of the angine connects to the air box and routes to the top of the carburetor intake hole in order to push air into the diaphragm which lifts the slide......Is this true? if so, is ther any easy way to put those cone filters on and get it to run??? can i just block off the vacuum???? idk at this point. I see people with b1s who have megaphone or cone filters on but idk how they did it!!
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- loudhvx
Re: Carburetor and engine vacuum system question b1
01 May 2011 00:22Not true. The big hose is just crankcase ventilation. You can just put a filter on it, or just run a big hose down to the ground, but don't let it get kinked.gumby prichard wrote: OK i ran into a huge problem i believe. i have a 78 kz400 b1. I want to put cone filters on my dual carbs. Problem is, i believe the vacuum hose on top of the angine connects to the air box and routes to the top of the carburetor intake hole in order to push air into the diaphragm which lifts the slide......Is this true?
Not without a lot of playing around with jetting.gumby prichard wrote: is ther any easy way to put those cone filters on and get it to run???
Some are just riding it not running correctly, and some have taken the time to rejet the carbs.gumby prichard wrote: I see people with b1s who have megaphone or cone filters on but idk how they did it!!
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
The following user(s) said Thank You: gumby prichard
- gumby prichard
01 May 2011 03:59
your so much help thanks! any links to threads that might lead me too the proper jet sizes?
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- loudhvx
01 May 2011 13:02 - 01 May 2011 13:08
Sorry. I've only done it on the older piston-slide Keihins, not the diaphragm ones.
Someone on the twins forum might be able to help, or at least might have some decent links.
If you really like fabricating custom stuff, you may want to look into making a 2-into-1 manifold and running a single, simpler carb. A few members on the twins forum have done that too, and it looks trick.
KZ400 twins forum
KZ400 twins forum
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 01 May 2011 13:08 by loudhvx.
- gumby prichard
01 May 2011 20:53
already did it!!!! lol but i want to switch because it doesnt make a very healthy sound.
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
