assembly lube for carb rebuild
- Darkangel
30 Apr 2011 18:34
what is recommended for assembly lube when rebuilding a set of carbs?
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
- bountyhunter
Re: assembly lube for carb rebuild
30 Apr 2011 20:15
I have seen some light grease used on the choke rods and external moving pieces, but nothing on the carbs themselves.
The following user(s) said Thank You: Darkangel
- Darkangel
30 Apr 2011 20:31
So nothing on the slides or anything else...I was going to put assembly lube on the connecting rod, and the choke
- bountyhunter
01 May 2011 02:58
absolutely nothing inside, they need to be squeaky clean.
- testarossa
01 May 2011 03:15Darkangel wrote: So nothing on the slides or anything else...I was going to put assembly lube on the connecting rod, and the choke
You can polish the slides and slide bores with Mother's but don't leave any residue. Just get everything clean and it should all work correctly.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- andy9802gt
- If it tastes that good, eat it yourself.
01 May 2011 08:01
If you're trying to gum them up, super glue should do the trick.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
- gordmccallum
01 May 2011 23:19
a previous post suggested xylene and an essential oil at 70/30 mix. I've forgotten what the oil was oh just remembered wintergreen I think, however where does one get Xylene??
- gordmccallum
01 May 2011 23:21
Sorry forgot to mention that I need to get the rubber boots soft again. That is the reason for the wintergreen / xylene mix. Suggestions??
