bike backfires
- kz73
bike backfires
30 Apr 2011 15:19
hello i have a kz900 with a '77 kz1000 motor in it(bike made to look like a a1 1000)i'm running pods on the carbs and a vance and hines pipe--when you fire the bike up,barely needs any choke--take off is fine,but when the bike warms up,starts to backfire--i know it is running a little on the rich side--but when you get on it(i go easy on these old babies),it takes off like a rocket--no running probs-just the backfiring issue--any ideas as to what to do?--any help would be great--it should be something tiny--
Re: bike backfires
30 Apr 2011 16:06
In order to get the carbs spot-on, you need to make sure that the valves are properly adjusted and that the cam chain is within spec. Also, the ignition system needs to be up to snuff - good spark? Advancer working properly? Good battery?
Last are the carbs. They need a good inline filter. Check fuel height by the clear tube method. Synch and adjust.
There are good tutorials on these things in the file base (there's a button near the top of this page). The factory shop manual is mighty helpful as well.
- kz73
Re: bike backfires
30 Apr 2011 18:57
changed the fuel filter--i'm stumped--went for a ride--smooth idle,smooth ride--but when you let off the gas--and downshift--that's when it starts talking to ya--then it stops--??:blink:
Re: bike backfires
30 Apr 2011 23:18 - 30 Apr 2011 23:20
Hello, kz73, and WELCOME to KZr!
Exhaust popping on deceleration sometimes results from too lean carb pilot circuit.
Would enrichen pilot circuit and test ride to see whether popping is affected.
Side-located pilot air screw (KZ900) would be turned in clockwise, say 1/4~1/2 turn.
Bottom-located pilot mixture screw (1977 KZ1000) would be turned out counter-clockwise, say 1/4~1/2 turn.
Last edit: 30 Apr 2011 23:20 by Patton.
- TNBOBBER
Re: bike backfires
05 May 2011 14:07
"Exhaust popping on deceleration sometimes results from too lean carb pilot circuit.
turn." Patton
If this corrects the popping, on a KZ1000 B4, is there something else needing done?
turn." Patton
Sometimes God doesn't calm the storm, He calms us in the storm.
- kz73
Re: bike backfires
05 May 2011 14:39
hello i changed the plugs from b7 to b8es and :woohoo: man,what a difference--doesn't backfire anymore--and i rode it around enough to get good and hot too--also reset the idle down to 1,000-man,what a difference--checked the plugs though and they are still getting sooty--wonder if setting the pilot(idle)jets would remedy this--i know a lot of this is trial and error when you add performance mods to any machine,but you guys have been great with the help as i don't like damaging these aging superbikes-going out to ride today-let you know how it doesB)
