carb selection
- ace
- 78kz1000
carb selection
30 Apr 2011 10:16
what are the best/favorite carbs for a stock 78 kz 1000. i believe mine are stock. would like to know what carbs fit and why. should i upgrade or not??? i run pods,dyna coils& ignition. every thing runs fine.plz explain mm size,flat sides,jet sizing and all that applies. the simpler the better for me!!if u could also give pricing,that would be great.....thanx ace.
78kz1000
- wireman
Re: carb selection
30 Apr 2011 10:53
26s were stock 28-29s will bolt on with little effort.
the newer style 28s are reasonably easy to work on and they will wake it up cheap,and i have a couple sets(main reason i like them! :woohoo: )
- ace
- 78kz1000
- wireman
Re: carb selection
30 Apr 2011 17:37
check your pm box
The following user(s) said Thank You: dejavoodo41
