running lean
  • Treewizard
  • Treewizard's Avatar Topic Author
running lean
25 Apr 2011 02:50
#446875
finally did a 'run @ 55 for 3 min, kill and read plugs' test
3 and 4 look a beautifull tan amd identical
1 and 2 are white in the same ammount
shall i turn the air screw on 1 and 2 in a quarter turn and do another test run or...
could this be a sync issue because its both 1 and 2 running lean equally
i synced the carbs and it runs rly smoooth, i rly cant see it being a sync issue
what do u think?
1983 KZ 750 shaft
2002 ZRX 1200R
Raleigh NC
Re: running lean
25 Apr 2011 10:05
#446901
Treewizard wrote: finally did a 'run @ 55 for 3 min, kill and read plugs' test
what do u think?
shall i turn the air screw on 1 and 2 in a quarter turn and do another test run --- Yes, provided it's to slightly enrichen the pilot circuit.
But, would first perform clear tube test to assure fuel height in float bowls isn't too low and thereby causing a too lean condition in the pilot circuit.
cant see it being a sync issue --- agreed, provided the bench sync was properly performed, and the subsequent running sync has not lowered slides excessively in #1 and #2 carbs as compared to #3 and #4.
Good Fortune! :)
