KZ 650 24MM Carbs Info???
- z1kzonly
24 Apr 2011 23:44 - 24 Apr 2011 23:49
I'm Z1900 & KZ1000! I have this set of 24mm intake, KZ650 carbs. Never been touched!
No Phillips head screw driver been on the bowls or the cross bar holding the housings on!
I will clean them, if they are worth selling, after 3-4 hours of labor.
Are they worth the value of the 26mm or the 28mm 900&1000's??
I see a center fuel line, 2 clear overflows. Is that a second neoprene hose for a vacumm petcock??
I tried downloading the PDF file and an excel file, that is in the archive. But my computer skills won't let me get there. I finally mastered pictures!
I take that back after seeing the picture! Someone had the bowls off, they are opposite drain holes! But the phillips heads have hardly been touched on all of the bowls
Thanks for any opinions on value and exact year & model
Marty in Buffalo
Marty in Buffalo
Last edit: 24 Apr 2011 23:49 by z1kzonly. Reason: missed information
- wireman
Re: KZ 650 24MM Carbs Info???
25 Apr 2011 01:01
i see a lot of them on ebay
- roy-b-boy-b
25 Apr 2011 03:45
They do not bring as much money as 26's. Roy
Last edit: 13 Feb 2013 12:58 by martin_csr.
