Question about KZ 650 Carbs
  • Darkangel
  • Darkangel's Avatar Topic Author
24 Apr 2011 04:45
#446663
Can anyone tell me what is the stock jets sizes for the VM carbs that came with a 81 Kz 650?
I am going to add pods to the bike, and Im keeping the stock exhaust, but I know I will need to rejet. does anyone know, can does anyone want to offer any advice?
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
  • martin_csr
  • martin_csr's Avatar
Re: -
24 Apr 2011 09:22 - 13 Feb 2013 12:56
#446673
Last edit: 13 Feb 2013 12:56 by martin_csr.
The following user(s) said Thank You: alskz
  • Darkangel
Re: Question about KZ 650 Carbs
24 Apr 2011 16:49
#446785
Right now it's just going to be pods with a stock exhaust. They say it should be just two sizes above stock jet sizes.
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
24 Apr 2011 17:10 - 24 Apr 2011 17:16
#446789
As I understand it Martin's figures are correct for the US models, while other markets certainly Canada, had the following mains 102.5. I have created a table of the carbs that came stock on which models with their respective internals from various parts lists that I have been able to find. I will say I can not prove the information is 100% correct, but I am pretty confident that it is very close. I have attached it to this post.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Last edit: 24 Apr 2011 17:16 by gd4now.
  • Darkangel
24 Apr 2011 20:44
#446825
that's pretty sweet amount of info that you have there...
  • martin_csr
Re: -
25 Apr 2011 12:51 - 13 Feb 2013 12:56
#446924
  • Darkangel
25 Apr 2011 19:23
#446990
Well ok... I've decided all i am doing is pods for right now. So what would you recommend me doing for main jets, and pilot jets. Also do i need to change out the needle jets or what?
  • Darkangel
30 Apr 2011 14:57
#447845
so would running 100 mains be ok with just the pod modification? Also when does the nettle jet, need to be changed, or Needle need washers?
  • Nebr_Rex
  • Nebr_Rex's Avatar
30 Apr 2011 15:45
#447850
Stock jets were 95 and 97.5 depending on model is what I've run across.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Nebr_Rex
  • Nebr_Rex's Avatar
30 Apr 2011 15:49
#447851
Darkangel wrote: so would running 100 mains be ok with just the pod modification? Also when does the nettle jet, need to be changed, or Needle need washers?
Try raising the needles and idle mixture screws first.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
  • Darkangel
30 Apr 2011 17:21
#447864
Ok you do that by adding the shims? and if I do that, will I have to undo what I've done when I do upgrade to the exhaust?
  • Godfrey
  • Godfrey's Avatar
02 May 2011 22:01
#448403
When I started messin with my 81 650csr the mains were 106's with the airbox, and Martin's right you can raise the needles stacking plastic washers under the clip, with open air cleaners I ended up runnin anywhere from 112-116 and thats with a 4 into one header.
1981 650CSR frame
1980 KZ750E engine
