leaking petcock
  • Brettstl
  • Brettstl's Avatar Topic Author
leaking petcock
20 Apr 2011 17:18
#445867
I took my 1982 kz750 out for about a hour ride today. when i went to park it i noticed it was idleing a bit low and actually died once. So i look under to where the on/off switch is under the tank i believe it is called a petcock was spitting out a bunch of gas. Its shooting out where its looks like a orange little rubber gasket piece that connects metal to metal. Is there a replacement part just for the little gasket? or am i going to have to buy a hole new petcock? and simple fixes?
1982 Kz750-H2
  • dblhdr
  • dblhdr's Avatar
Re: leaking petcock
20 Apr 2011 17:43
#445876
check at Z1 Enterprises they have diphragms and replacement petcocks available. You may have to do some research to find just what you need but they are great folks and will help a lot. ( yes they do sponsor this site but I'm just a customer.)
1981 KZ1000 Police Special coverted for civilian use with passenger seat, custom luggage rack, and paint. Daily rider.
2006 Harley Davidson Road King FLHR1
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: leaking petcock
20 Apr 2011 17:44 - 20 Apr 2011 17:46
#445878
Try these guys:
www.z1enterprises.com/reference/petcock.aspx
Dont be afraid to just call and ask, they are very friendly and helpful.
PS. The KZ750H2 is an 81.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 20 Apr 2011 17:46 by TeK9iNe.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: leaking petcock
20 Apr 2011 17:47
#445880
Make sure it's actually the petcock leaking and not a split line.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • Brettstl
Re: leaking petcock
20 Apr 2011 18:17
#445887
www.bikebandit.com/houseofmotorcycles/19...-us/o/m3257#sch87012
i found this diagram on bike bandit. its leaking between 18 and 21...i guess its the DIAPHRAGM ASSY,TAP...guess ill be ordering that.
1982 Kz750-H2
  • MFolks
  • MFolks's Avatar
Re: leaking petcock
20 Apr 2011 18:52
#445894
This Gasoline-Alcohol mix being forced upon us (E-10,E15 & E85) will cause the rubber bits in our older bike's fuel system to quickly fail in a relatively short time. Check anything that touches this stuff for signs of cracking,or you may be stranded some day.
  • Brettstl
Re: leaking petcock
21 Apr 2011 12:49
#446045
thanks guys for all the help!
1982 Kz750-H2
Re: leaking petcock
21 Apr 2011 13:12
#446052
Would suggest considering Z1E as parts source.
www.z1enterprises.com/detail.aspx?ID=307
www.z1enterprises.com/detail.aspx?ID=305
Good Fortune! :)
  • Brettstl
Re: leaking petcock
25 Apr 2011 22:21
#447031
Is there a way to take the petcock off the tank without having to take it off the bike? Only reason I ask is because to take the tank off my bike is a huge hassle. Would I be able to replace the diagram without taking the tank off....like does it disconnect from the bottom of the tank somehow?
1982 Kz750-H2
