Vacuum leak?
  • KZcali
  • KZcali 's Avatar Topic Author
Vacuum leak?
19 Apr 2011 20:32
#445688
Attachment IMG00145-20110407-1437.jpg not found
Hello all,
Noob here. just pulled my brothers 82 Kz750-n1-spectra out of the garage after its 2yr hiatus. Wanted to get it running again so I started with the standard tune up, New battery, plugs, air filter, oil/filter. Got the beast running!!! BUT... when i start it cold it wont stay at idle. I can ride it choked for a wile (10miles) then turn the choke off and it will stay idling. i know its a cold blooded animal but it shouldnt take that long to warm up. I pulled the new plugs and they are white. Leading me to believe there is mixture issue? i sprayed starter fluid around the carb area and the engine reved up. so i replaced all the vacuum lines and checked the "boots" going from the carbs to the air cleaner and to the engine. still have a idle issue. i didnt replace boots... if they feel and look fine should i replace them??
sorry for the rookie mistakes...this is a rambling cry for help. any advice would be greatly appreciated
  • P21
  • P21's Avatar
Re: Vacuum leak?
19 Apr 2011 20:51
#445694
well if your boots are leaking air will need replaced.
sounds like pilot circut is junked up try half bottle of Sea-Foam and see what happens but if your boots are leaking all bets are off.
Kawasaki KZ 1000 Police (2002) P21
The following user(s) said Thank You: KZcali
  • P21
  • P21's Avatar
Re: Vacuum leak?
19 Apr 2011 20:55
#445695
Boot
  • KZcali
Re: Vacuum leak?
19 Apr 2011 22:03
#445702
I actually ran about a half bottle of sea-foam through the tank. Im planning on putting the other half in when i refill the tank. If it was the boots why would it eventually hold an steady idle? And where do you recommend I get new boots?
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
Re: Vacuum leak?
19 Apr 2011 22:09
#445708
All your parts needs.
I replaced my boots today. They are less than ten years old.
I would just ride the bike a few more miles.
If you haven't cleaned the jets out you might consider that. Roy
www.z1enterprises.com/
  • KZcali
Re: Vacuum leak?
19 Apr 2011 22:23
#445712
Im also under the assumption i have a blown head gasket because i have oil all over jugs. Would this cause bad idle?
