KZ1000P Carbs
  • den73160
  • den73160's Avatar Topic Author
KZ1000P Carbs
18 Apr 2011 13:08
#445327
I am working on restoring a '97 KZ1000P. When I got it the carbs were off, now when trying to reattach them do not know where the vaccum lines hook up to. Anyone shed some light on this for me. I know that 2 lines go to the air reed valve, but does one go to the petcock and what about the fourth one?
  • Motor Head
  • Motor Head's Avatar
Re: KZ1000P Carbs
18 Apr 2011 14:39
#445336
Assuming that the 97 is the same as the older models, the 2 outboard carb nipples 1&4 would go to the vacuum switch for the Air System. Then #3 would go to the petcock vacuum fitting, and #2 would be capped.
Hope this helps.
Pictures are always welcome.
