29mm float bowls
- juliorice
Re: 29mm float bowls
09 Apr 2011 16:15
I'm confused. How can this be? Everything I have seen on the 29mm smoothbores shows only a single fuel feed, including the exploded view in the books. What do 29mm smoothbores look like? The pics at Z1 also show a single fuel feed. Not trying to be a dick, just confused and would like clarification. Thanks. Julio
- Jeff.Saunders
09 Apr 2011 16:28
My mistake on the single versus dual fuel feeds. I had a set of VM28's sitting on my desk...
www.z1enterprises.com
Z1 Ent on Facebook,
- juliorice
- wireman
09 Apr 2011 16:38are you sure about that jeff? i believe wg still owes me a steak over that bet. :woohoo:Jeff.Saunders wrote: [strike]The carbs in first post are not VM29's... they appear to be 26's or 28's from a KZ1000. All the VM29's had [strike]dual[/strike] single fuel feeds.. Those brass spigots are from the accelerator pump version of the carbs. But the carbs themself don't have the nozzels pointing down the throat of the bore - so it looks like those bowls came from a 79/80 model, where the carbs themselves are probably 77/78 vintage.[/strike]
The float bowls for the VM29's DO NOT interchange with the VM26 or VM28 carbs.
- trianglelaguna
09 Apr 2011 16:42
x2...swap can be made imo...what carbs they are i do not know as i dont click pics...always thought the bowls swapped too....hmmmmm
wireman wrote:are you sure about that jeff? i believe wg still owes me a steak over that bet. :woohoo:Jeff.Saunders wrote: [strike]The carbs in first post are not VM29's... they appear to be 26's or 28's from a KZ1000. All the VM29's had [strike]dual[/strike] single fuel feeds.. Those brass spigots are from the accelerator pump version of the carbs. But the carbs themself don't have the nozzels pointing down the throat of the bore - so it looks like those bowls came from a 79/80 model, where the carbs themselves are probably 77/78 vintage.[/strike]
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- jeffasaki
09 Apr 2011 17:16
Keep what you have,get a accelerater pump and install it.
Some 29s did come with the pump and are super rare
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- gane
09 Apr 2011 22:04
Toad, My experiance w/29 smoothies is limited having only delt w/3 or 4 sets.however, to my knowledge the original bowls had a 17mm headed drain & no provision for an overflow tube, THUS, if there was ever a float valve prob, raw gas wound up 1st in the air filter, & then intake tract (see crankcase) Look at your present bowls... if the spigot on the outside links to a brass tube which extends to about the seam of bowl to body, & seals, KEEP THEM ! regardless of what they came off, the merits of an overflow precaution far outweigh the ability to swap main jets on the fly... Dont plug spigots, run drain tubes.. Just my 2 cents G
[img][/img] 1977 KZ1000A1
- toad
09 Apr 2011 23:35
that makes sense and yes they do have that brass tube.I have spotted a little gas come out of the spigots before, anyway I have nnot seen before other smoothbores with the same float bowls.
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
