81' Kz 750 keihin CV34 carb problem?
  • kzcafe750_24
  • kzcafe750_24's Avatar Topic Author
06 Apr 2011 23:51
#443130
Hey guys,
Well finally got my bike on the road this week, for the first time after the rebuild. But I am having a bit of a problem with the carbs I believe. The bike starts right up cold or warm; and pulls hard up to 5500-6000rpm and starts to cut out and if you hold it long enough it comes out of it around 7000rpm and pulls hard again all the way up, this all under hard accearation "1/2 throttle or more"! But if you ease it up and past 6000rpms then crack it open it stumbles a little then goes like a mad man. I am thinking it has to be sticky slides or air/fuel mixture is not right? I took the plugs out after riding it for a bit and they look practically like new.? Oh, and I have yet to sync the carbs, but i did bench sync them.
Any help would be great thanks
Little info on my bike:
81 kz 750-4 LTD
- 4 into 1 exhaust (No baffle) Yet, but need one toooo loud!
- Dyna S ignition (wiredgeroge convertion)
- Dyna 3 ohm coils
- 83 Gpz intake cam
- Degreeable cams
- 135 main jet (stock 125)
- 35 pilot jet (stock) just order bigger pilot jets (37.5)
1981 Kz 750-4 LTD - Wiseco 810 Big Bore,Ported cylinder head, GPZ 750 Cams,Dyna Ignition(DynaS,Green Coils,DRL400 2stage Revlimiter), RC 4 into 1 fitted with Yoshi muffler, ZR550 Swing arm, ZR550 Rear Rim, ZX750turbo front end SuperFlo Dyno Tuned- 68WHP&43WTq(ftlbs)
1986 Honda Rebel 250 (Stock)
1985...
  • Betraying HD
  • Betraying HD's Avatar
Re: 81' Kz 750 keihin CV34 carb problem?
07 Apr 2011 01:07
#443152
Yeah man I just bought an 82 ltd and had the same problem. I just changed out the intake manifolds that go to the block. Extra airs getting in.
Check it out by spraying starting fluid on the boots and the idle should climb with out the choke.
  • kzcafe750_24
07 Apr 2011 12:28
#443224
Ya ill check it out, but just thought that if air were getting past the intake boot on the engine side it would hang and rev stay up. But ill try the propane and see what happens.
Thanks
1985...
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
07 Apr 2011 15:08 - 07 Apr 2011 15:15
#443244
You are still using the airbox w/stock filter?
Your needles could be too lean... could try lifting needles one position and test.
Read this info about checking plugs: www.angelfire.com/fl4/pontiacdude428/Readplugs.html
Make sure to read at the end about unleaded gas. Its totally accurate, especially with high efficiency ignition systems, your plugs will stay very clean/whitish, even when jetted too rich.
B)
Jet chart:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 07 Apr 2011 15:15 by TeK9iNe.
  • kzcafe750_24
08 Apr 2011 21:35
#443489
Ya I am using the stock air box, but I have the stock style uni filter for it.
But I going to shim the needles up a little bit and hopfully that'll help out. Finally put packing in my exhaust so it is quiter now and has a little more back pressure.
Thanks for the info!
Dylon
1985...
