1983 KZ 750 L3
- pikk292
1983 KZ 750 L3
06 Apr 2011 18:22
Hey All,
I own an 83 KZ 750 4 cyl. I recently added larger jets, 4 into 1 exhaust with a kerker pipe and pod filters. My issue is, although the bike screams once at and over 5000 rpm, getting there seems sluggish and slow. Specifically...no bottom end. I'm wondering if someone can offer some insight to this. I drove an 82 (same bike essentially) and it has way more bottom end than mine. Perhaps I'm missing something. I've installed 115 Main jets and raised my jet needles to the second last position. Pilot jet screws are set to factory. Compression is good, everything else checks out. Only thing I didn't look at (as someone else suggested) was the timing advancer. Any help would be appreciated.
TIA
Pikk
TIA
Pikk
- M357.5
- Kwakas N' lots of em'
Re: 1983 KZ 750 L3
06 Apr 2011 18:56
I was talking with Otakar on the board here about rejetting my 84 750L and he suggested 120's and possibly even 122.5's for a pipe and pod's. I've jetted my carbs with the 120's but havent run it yet. Maybe something to look into.
83 KZ750L X2 + goodies = Project
84 KZ750L the mini ELR replica replica lol
84 ZX750E Turbo modded n' FAAAAASSSSSSTTTTT
85 GPz900r GREEN N' MEAN
- pikk292
Re: 1983 KZ 750 L3
06 Apr 2011 19:31
Hmm...might be an idea. Although the guy at the Kawasaki dealer who knows these bikes well said 115's should be all I need. Damn ole' bikes. They are a picky bunch. LOL!
Thanks for the reply!
Last edit: 12 Feb 2013 12:24 by martin_csr.
- apbling
Re: 1983 KZ 750 L3
07 Apr 2011 11:12
does this bike have the CV 34's?
Maybe try to richen the pilots up a bit to see if that helps?
- pikk292
- pikk292
Re: 1983 KZ 750 L3
10 Apr 2011 10:05
Well, after a good run this weekend...I'm pretty sure my Mains are way too small. I've been reading some stuff about these Mikunis on these bikes and I should be at a minimum 140 main jets. I couldn't get the thing past 6500 RPM without it bogging down...begging almost, for fuel. lol! Also heard I need larger pilots. I'm going to try 140's and 42 Pilots. If anyone has experience with these and wants to weigh in, I'm open for suggestions. Any help would be appreciated.
Thanks!
Pikk
Thanks!
Pikk
Re: 1983 KZ 750 L3
10 Apr 2011 14:02 - 10 Apr 2011 14:03
If not already done, would test run with fuel cap ajar to see whether that makes any difference.
While at it, also add a little choke during the bogging to see if that makes any difference.
Results of these test may aid diagnosis.
Last edit: 10 Apr 2011 14:03 by Patton.
- pikk292
Re: 1983 KZ 750 L3
10 Apr 2011 14:26
Good Idea, Patton. The choke on may indicate it's getting too much air...not enough fuel.
Thanks!
Thanks!
