tk22 carbs on a 81 kz550ltd
  • moose
  • moose's Avatar Topic Author
03 Apr 2011 18:38
#442399
hey guys i am trying to sync my carbs how many inch lbs of vacuum should they be at idle and what is the best rpm to set them at to check them ...again tk22s on a 81 kz550 ltd
  • SPARKY47
  • SPARKY47's Avatar
  • 1980 KZ500 B2
Re: tk22 carbs on a 81 kz550ltd
04 Apr 2011 00:50 - 04 Apr 2011 00:58
#442487
If your machine is the same as a 80 550 A1 (or a Z500 B2) then:
19-24 cm Hg. Difference between any two cylinders should be less than 2 cm Hg.
At idle speed.
Taken from factory manual for KZ400/500/550.
Sorry converting to inch pounds boggles my mind.
There used to be a manual somewhere on this site, someone else will know where.
1980 KZ500 B2
Last edit: 04 Apr 2011 00:58 by SPARKY47. Reason: I'm old.
