nightmare part 4
  • allen6634
  • allen6634's Avatar Topic Author
nightmare part 4
12 Mar 2011 06:54
#437293
i have tryed to jet the carbs down, and now my #2 &3 cly isn't hitting, i am at a loss have taken the carbs back off and haven't found anything ovbious as to why i have lost 2 and 3 realy don't know what to do next my bike has t.k. carbs so i don't know who makes them, have called some shops and one said my bike has mikuni, and the other said keihin.being that my carbs are off i would like to put bigger pilot jets in because of the fact the bike would pop when i let off the throttle. thanks in advance for everyones advice it is not wasted.
1983 kz 550 m
  • Old Man Rock
  • Old Man Rock's Avatar
Re: nightmare part 4
12 Mar 2011 06:57
#437295
Lost 2 & 3 meaning?
Keep in mind, 2/3 are on the same coil, sure it's not electrical?
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • stonemaster
  • stonemaster's Avatar
12 Mar 2011 06:59
#437298
what do you mean by "not hitting" if they're not firing its electrical, u do know 2 and 3 fire off the same coil right???
  • allen6634
12 Mar 2011 07:01
#437299
im sorry for not being clear i am getting fire to the plugs just not running on them cly.
1983 kz 550 m
  • stonemaster
12 Mar 2011 07:02
#437300
damn dude you type faster :angry:
  • stonemaster
12 Mar 2011 07:05
#437301
did u mess with the timing plate any, 2 and 3 also fire off the same set of points, u could get fire but worky, if not take em carbs back off and go throuh em again, check passages, bench sync, etc,etc
  • Old Man Rock
12 Mar 2011 07:18
#437307
"i am getting fire to the plugs " but correct ignition spark is the question....;)
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • allen6634
12 Mar 2011 07:25
#437311
i have my carbs off and being that my bike would pop as i let off the the throttel i figured id put some bigger pilot jets in. but i can't find any . my bike has ele ignition and i have never touched the timming plate but i may try this time . my main thing is i need to check the coil and plugs today.so it sounds like i have my work planed for today. thanks.
1983 kz 550 m
  • stonemaster
12 Mar 2011 07:31
#437314
be meticulous, do ONE THING AT A TIME, make a list, AND DONT GET EXCITED good luck :woohoo:
12 Mar 2011 07:45 - 12 Mar 2011 07:46
#437324
allen6634 wrote:
...bike would pop as i let off the the throttel i figured id put some bigger pilot jets in. but i can't find any ....
Often just a simple pilot circuit enrichment will eliminate popping on deceleration.
A different pilot jet is often unnecessary.
Simply use the pilot adjustment screws.
Each carb has its own pilot adjustment screw.
An air leak (intrusion of outside air into the air-fuel mixture being provided from the carb to the engine) will also cause popping on decel and also a racing idle.
One typical leak site (of several possibilities) is at the carb holder (loose clamp for example) or cracks in an old worn out carb holder.
Good Fortune! :)
Last edit: 12 Mar 2011 07:46 by Patton.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
12 Mar 2011 08:34
#437333
+1 Absolutely. Turn those mix screws, and turn up your idle. Check by misting some water on the pipes, to see if the 2-3 start running again. If they do, then your sync is probly terrible. If not, then you gots another issue...
Make sure fuel levels are all correct/the same, and make sure pilot passages on carbs are flowing fuel correcty by spraying cleaner through the pilot jet opening, and watching it spray in the bore.
Good luck!
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • allen6634
12 Mar 2011 14:51
#437434
you was right my whole problem was in the sync. i spent all day tinkering with the bike,and found that it was way out of sync. next good day i will put the gages on to make sure im on point.
1983 kz 550 m
