Bigger carbs
  • Leathal
  • Leathal's Avatar Topic Author
Bigger carbs
11 Mar 2011 19:55
#437174
Hi all am new here.
I am building a big bore 750 and am looking to put bigger carbs on it.
What are the recommended upgrade? from which bike?
Ok here is what I am running.
810 big bore with raised compression. Fully ceramic coated
The head is shaved. coated and ported. stock valves
big set of Web cams and an exhaust.
Any help would be appreciated.
Thanks
  • DoubleDub
  • DoubleDub's Avatar
Re: Bigger carbs
11 Mar 2011 20:04
#437177
I know some guys who put the Mikuni VM26SS Round Slide carbs from the Kz900/Kz1000's on there. Haven't done it personally so I can't speak to performance.
  • wireman
  • wireman's Avatar
Re: Bigger carbs
11 Mar 2011 20:08
#437181
maybe a set of vm 28s or some 29 crs B)
  • Leathal
Re: Bigger carbs
11 Mar 2011 21:22
#437205
Do any of the GSXR flat slide fit?
  • Leathal
Re: Bigger carbs
11 Mar 2011 22:35
#437220
Ok have done a little more research. Its a 1990 model 750 zephyr.
It has on it now a set of keihin CVK32's
Now the GPZ750's came out with Mikuni 36's
Should I switch to the Mikuni or go and fit a race set of factory pro jets to the keihins?
  • wireman
  • wireman's Avatar
Re: Bigger carbs
11 Mar 2011 22:40
#437222
yeah the newer motors have a lot bigger ports than the older 650/750s.
  • Leathal
Re: Bigger carbs
12 Mar 2011 18:21
#437509
So should I stick with the kehein 32's or chase up a set of Mikuni 36's?
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: Bigger carbs
12 Mar 2011 18:32
#437514
Stick with'em, they'll be fine.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • wireman
  • wireman's Avatar
Re: Bigger carbs
12 Mar 2011 18:34
#437515
ive seen a lot bigger motors run really well on smaller carbs than 36s myself.
my 1327 runs really well with an old set of 33 smoothbores,i know of a really good running 1385 with 36 flatslides but thats just my experiance anyway. B)
  • Leathal
Re: Bigger carbs
12 Mar 2011 18:43
#437519
Cool I will just jet up the ones I have and go with that for now.. And if they don't keep up then I'll look at going bigger. Maybe then fuel inj in stead.
