Quick float height question
  • ravenz07
  • ravenz07's Avatar Topic Author
07 Mar 2011 18:22
#436015
I have looked, but there seems to be a few different responses as far as float height. I am about to get the carbs set up and tuned. What would be the ideal measurement for the floats during a wet test in distance from the carb body?
(1980 Kawasaki KZ750 LTDH 4 cylinder)
1994 Kawasaki KZ1000 Police
1981 Yamaha XJ650H Maxim
  • moneypit
  • moneypit's Avatar
Re: Quick float height question
07 Mar 2011 20:21 - 07 Mar 2011 20:22
#436043
Pic stolen from another thread, heres the link kzrider.com/index.php?option=com_kunena&...mit=20&limitstart=20 says 2-4 mm below carb body.
2-76 kz900
St Paul MN
Last edit: 07 Mar 2011 20:22 by moneypit.
  • ravenz07
07 Mar 2011 21:26
#436062
So 3 should be that magic number than? My carbs are the Keihin carbs, is it the same?
07 Mar 2011 21:49
#436064
This link might help
Click > kzrider.com/index.php?option=com_kunena&...ew&catid=3&id=169736
Good Fortune! :)
  • stonemaster
  • stonemaster's Avatar
07 Mar 2011 21:52
#436065
for me it comes out to about the bottom of the lip below the red line
  • ravenz07
07 Mar 2011 22:46
#436074
I see what you mean, on the link provided by Patton (thanks btw!) it seems the fuel level is at the bottom edge of where the screws go into the float bowls. That is what you are meaning right stone?
  • stonemaster
08 Mar 2011 04:49 - 08 Mar 2011 04:57
#436087
yep at least on my vm 28's it was so I would say so, looks like u got the 17 mm float bowl screw as well, I made a variation of the float level tube, might make things a little easier for ya. kzrider.com/index.php?option=com_kunena&...atid=21&id=385849e's
Last edit: 08 Mar 2011 04:57 by stonemaster.
  • ravenz07
08 Mar 2011 09:36
#436154
Wow that is a neat setup, any idea exactly what the sizes and such were for the fittings?
  • martin_csr
  • martin_csr's Avatar
Re: -
08 Mar 2011 10:40 - 11 Feb 2013 18:12
#436176
Last edit: 11 Feb 2013 18:12 by martin_csr.
  • stonemaster
08 Mar 2011 12:51
#436206
plumbing section at Lowes, the threads and sizes didnt match exactly but a file will take em down to size and plastic threads easily
  • Sallzy
  • Sallzy's Avatar
08 Mar 2011 14:41
#436234
is there a substiute that can be used instead of gas for bench setting the level? dry gas? mineral spirits? does anyone use something other than gas? or is it best to just use gas?
08 Mar 2011 14:55
#436238
A substitute would need to have the same specific gravity (relative density) as gasoline or the floats would float at a different level giving an inaccurate reading. I don't know of any other fluid (hopefully one that’s not flammable) with the same specific gravity as gasoline. Maybe someone well versed in chemistry can chime in. Ed
