nightmare part 3
  • allen6634
  • allen6634's Avatar Topic Author
nightmare part 3
07 Mar 2011 13:58
#435942
today i found success with my bike partly. turns out that i am going to have to jet the thing my bike will not take fuel it starts to flood as soon as the rpms increase,will headers allow the bike to run richer? i am thinking about going down in jet size.i am going to start with 100 jets istead ofthe 120s that are in it now then i am going to try droping the needle down one notch at a time.the bike purrs like a kitten now but only if i can get it to rev. i did everything that everyone suggested. thanks for the help i am gratful.
1983 kz 550 m
  • stonemaster
  • stonemaster's Avatar
Re: nightmare part 3
07 Mar 2011 15:16
#435969
whatever u do DONT do two things at once, do one at a time,
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
07 Mar 2011 15:34 - 07 Mar 2011 15:44
#435972
I don't know for sure but I think even the 100 mains will be rich also. Your needle should ride in between slots #2 and #4 on a 5 position needle, if you have to go full lean on the needle it's jetted way to fat on the main and you will need to drop a size and recheck and so on and so forth until you get in the ballpark. If you get really close and needle clip changes won't get it dialed you will have to find the next needle in the direction you want to go. If a needle change occurs you may likely find yourself rejetting to account for the different mixture of the new needle. And like stonemaster said only one change at a time otherwise you'll be scratching your head trying to figure it all out.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Last edit: 07 Mar 2011 15:44 by andy9802gt.
  • allen6634
08 Mar 2011 03:45 - 08 Mar 2011 14:45
#436083
well i got to install the new jets on today,now my #2 and 3 cly isn't running,this bike amazes me! so next chance i get i willrun some tests mainly with the clys i suspect it can't be in the carbs after i have them appert three times.i have never had something this diffacult.
1983 kz 550 m
Last edit: 08 Mar 2011 14:45 by allen6634.
