who can identify what this thing is?
  • metrorollah
  • metrorollah's Avatar Topic Author
06 Mar 2011 22:20
#435787
Hi all,
I have carbs that run great. That being said, I am missing the three-screw cover shown in this pic. What the heck is that thing? Does it really need a cover?
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: who can identify what this thing is?
06 Mar 2011 22:30
#435789
I could certainly be wrong as it is hard to tell just which carbs the pic is of, but I think that is part of an Accelerator pump. Some sets have the place for one but do not have the pump installed. If your set is not making use of one then no it is not needed. Having said all of that, I am sure others will chime in with more info.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • Nebr_Rex
  • Nebr_Rex's Avatar
06 Mar 2011 23:28
#435795
First time I have seen that cover.
Usually not used,left blank,unmachined.
The acc. pump is the cover with 4 screws.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • stonemaster
  • stonemaster's Avatar
06 Mar 2011 23:36 - 07 Mar 2011 06:43
#435800
thats gotta have something to do with emissions control, WTF carb is that anyway
ooopppps bad guess :(
Last edit: 07 Mar 2011 06:43 by stonemaster.
  • larrycavan
  • larrycavan's Avatar
07 Mar 2011 05:02 - 07 Mar 2011 05:06
#435809
It's part of the accelerator pump. The 79 LTD 1000's have that on them. As was mentioned, not all models with the pump have that extra cover. I think the 80 LTD model came without it.I forget it's exact function but I will check the manual today. It's a check valve for the pump as I recall.
There's a fuel passage that will either be drilled or not. If yours had the drilled passage and the cover was missing, fuel would be running out of the hole.
www.bikebandit.com/houseofmotorcycles/19...td/o/m9905#sch424813
Larry C
Last edit: 07 Mar 2011 05:06 by larrycavan.
  • metrorollah
07 Mar 2011 08:46 - 09 Mar 2011 12:49
#435855
Awesome, thanks Larry. I guess the carbs currently on my 1979 KZ650D2-SR did not need that cover. There is a plate there, and no sign of a diaphragm.
Separately, none of the 650cc models show an accelerator pump at all. I am starting to wonder if I may have carbs non-original to my model.
Last edit: 09 Mar 2011 12:49 by metrorollah.
  • gd4now
  • gd4now's Avatar
07 Mar 2011 08:59
#435858
Starting in mid to late 78 many / most of the kz650s sold in the US had accelerator pumps. IIRC they were added to meet EPA requirements.
1977 KZ650 B1
  • metrorollah
07 Mar 2011 09:09 - 07 Mar 2011 09:11
#435861
thanks. So, I have the correct carbs I think, and the accelerator pump does not have a replaceable diaphragm there. great insight.
Mine is machined for that cover though, there are screw holes.
Last edit: 07 Mar 2011 09:11 by metrorollah.
  • tinlizzie37
  • tinlizzie37's Avatar
07 Mar 2011 10:08
#435873
Some guys disconnect the actuating rod from the diaphragm lever, doing away with the accelerator pump. My KZ 650 E 1 has a working one on it. Bob
Bob KZ 650 E1, En 450
  • gd4now
  • gd4now's Avatar
07 Mar 2011 10:23
#435878
Here is a pic from a B model parts list showing the pump. It does show both of the parts in question, but as was said not all of the carbs made use of both.
1977 KZ650 B1
  • metrorollah
09 Mar 2011 00:05
#436430
So, this one then, Larry, does not have the drilled passage you speak of, correct?
  • larrycavan
09 Mar 2011 05:25
#436450
Right, I don't see the hole for the pin that's part of the diaphragm to go into.
I would leave the pump hooked up and not mess with it's adjustment. That was actually a nice feature to have IMO.
Larry C
