Rejetting?
  • IowaKzfan
  • IowaKzfan's Avatar Topic Author
Rejetting?
06 Mar 2011 13:33
#435599
My 81 Kz750 E has an air box in it. I want to switch to say K&N slip on filters individually for each carb,the question I have is will I have to rejet because of increased air flow?
  • RunDog
  • RunDog's Avatar
Re: Rejetting?
06 Mar 2011 13:41
#435604
Yes and good luck You will need a jet kit. Pod filters are very finicky. If you have not tuned carbs before you are in for a real treat. I am doing same thing as we speak Ive taken my carbs off 6 times. I am getting close. If your a machanic you should have know troubles. But my suggestion is leave it. Unless you are a very patient person Good luck
  • JR
  • JR's Avatar
Re: Rejetting?
06 Mar 2011 14:49
#435641
Yes you will need to re jet.
Is your exhaust the original 4 ->2 ?
When I bought my bike (1980 750 E1) 8 years ago it had a 4->1 Exhaust and K&N pods on it.
I eventually found that the best jetting was to have the secondary main at 140 (stock 125) and the primary main at 70 (stock 62 I think). Air mixture screws 2 turns out. If you have the 4->2 then you should try a tad lower jet numbers.
Last summer looking for a more stock look I put an airbox on it and jetted down. Much better at lower speeds.
Pods look cool, are good at higher speeds if you jet right but they dont like getting caught in the rain.
Keihin Jets are available from Z1Enterprises.
Good Luck
  • Polar_Bus
  • Polar_Bus's Avatar
Re: Rejetting?
07 Mar 2011 06:17
#435814
Don't do it !!
Do some searching under "pods" and "jetting" and you will archive a years worth of reading. After your new education on pods, you will hopefully decide to keep your stock airbox.
Bikes:
'84 GPz1100
'06 HD Fatboy
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: Rejetting?
07 Mar 2011 08:30 - 07 Mar 2011 08:32
#435849
Absolutely, yes.
Remember, pods are for people who want to utilize the high rpm band power of an engine - mostly racing. Also - its not the kind of power boost your thinking - not much difference really till you on the highway/at high speeds.
Rejetting to make pods usable at lower rpms requires the installation of a proper kit, especially for those without experience.
You can put them on, but it will take many hours of tuning to make them usable/more power than your stock air box at low rpm. Mid and high rpm especially will benefit, but only with the correct setup.
Best of luck.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 07 Mar 2011 08:32 by TeK9iNe.
  • IowaKzfan
Re: Rejetting?
07 Mar 2011 09:32
#435865
I am not a mechanic,and so...with all that I am hearing in the negative aspect,I think I will just keep using the air box filters. Thanks for all the input to everyone out there.
