Dented float bowl?
- mtbspeedfreak
Dented float bowl?
27 Feb 2011 23:39
I was washing my old gal the other day and noticed the #4 carb float bowl seemed to be dented in. I've put almost 15,000 miles on it in 9 months, so it's not keeping the engine from running properly (it gets HORRIBLE gas mileage, but I doubt this is the problem).
I'll be popping my carb cherry in the next month or two and rejetting in hopes of getting the mileage back up to where it should be and was wondering if a dented float bowl would adversely affect the fine tuning.
Thanks!
Thanks!
2000 ZRX 1100
1976 KZ 900- Daily Driver
- mtbspeedfreak
Re: Dented float bowl?
27 Feb 2011 23:41
Maybe someone might have a spare float bowl for a VM26 lying around they'd like to part with???
2000 ZRX 1100
28 Feb 2011 12:50
Can you post a pic? That sounds odd. I had no idea that cast cheapometal would dent rather than crack and break.
- TeK9iNe
- What did you do!?!
28 Feb 2011 13:46
TexasKZ wrote:
+1 If its a mini-dent, I wouldnt give at any real thought.
Then again, I'm sure someone has one for you. When in doubt, replace.
you mileage is horrible because you use large amounts of throttle all the time, or your mixture screws and pilot circuit is poorly tuned, and/or vacuum balance is bad.
Peace.
Peace.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- mtbspeedfreak
28 Feb 2011 20:54
2000 ZRX 1100
- TeK9iNe
01 Mar 2011 06:02
mtbspeedfreak wrote:
:laugh: Right... so grabbing lots of throttle then.
I wouldnt be too concerned aout that little guy. It might make a miniscule difference, but i'm sure theres lots of other little things going on that mask that anyways.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
